1993 Mustang---Alternator not charging----PLEASE HELP
brienjohnson200
Edmonton
I have 87-93 Mustang (Vortech blower, aftermarket fuel management, 3G alternator etc) and the alternator will not charge. Alternator did work. I have the battery located in trunk, with a on/off switch by the license plate. This car has been completely re-wired and doesn't use much of the stock wiring anymore. Battery cables were hooked up backwards once on the car, boosting this car. This is some of the stuff I have tried:
1. Tried two alternators (both tested good at the parts store).
2. Changed all wires (alternator to kill switch, kill switch to starter relay). I just ran the new wire outside of the car just to test it. After I tested both wires one by one then I had to hook up the old wire since I only had one long test wire (trunk to engine).
3. Tried 2 different batteries.
4. Changed the plug at the alternator and re-wired it (white/black--plug back to alternator, yellow---plug to + post on alternator, green/orange to wire that was used with old plug where it had worked a while ago).
PLEASE ANY HELP WOULD BE GREATLY APPRECIATED!!!!
Never, never disconnect an alternator from the battery with the engine running. The resulting voltage spike can damage the car's electronics including the alternator.
Do all of these tests in sequence. Do not skip around. The results of each test depend on the results of the previous tests for correct interpretation.
Alternator troubleshooting for 86-95 5.0 Mustangs:
Engine off, ignition off, battery fully charged.
1.) Look for 12 volts at the alternator output. No 12 volts and the dark green fuse link between the orange/black wires and the battery side of the starter solenoid has open circuited.
3G alternator: Look for 12 volts at the stud on the back of the alternator where the 4 gauge power feed wire is bolted.
No voltage and the fuse for the 4 gauge power feed wire is open or there are some loose connections.
2.) Look for 12 volts on the yellow/white wire that is the power feed to the regulator. No 12 volts, and the fuse link for the yellow/white wire has open circuited.
Engine off, ignition on, battery fully charged.
1.) Alternator warning light should glow. No glow, bulb has burned out or there is a break in the wiring between the regulator plug and the dash. The warning light supplies an exciter voltage that tells the regulator to turn on. There is a 500 ohm resistor in parallel with the warning light so that if the bulb burns out, the regulator still gets the exciter voltage.
Disconnect the D connector with the 3 wires (yellow/white, white/black and green/red) from the voltage regulator.
Measure the voltage on the Lt green/red wire. It should be 12 volts. No 12 volts and the wire is broken, or the 500 ohm resistor and dash indicator lamp are bad. If the 12 volts is missing, replace the warning lamp. If after replacing the warning lamp, the test fails again, the wiring between the warning lamp and the alternator is faulty. The warning lamp circuit is part of the instrument panel and contains some connectors that may cause problems.
2.) Reconnect the D plug to the alternator
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed regulator. This is an actual measurement taken from a car with a working electrical system.
Engine on, Ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see battery voltage minus .25 to 1.0 volt. If the battery measured across the battery is 15.25 volts, you should see 14.50 volts
Familiarize yourself with the following application note from Fluke: See Automotive Test Tools for help for help troubleshooting voltage drops across connections and components. . You will need to do some voltage drop testing of several of the wires.
Start looking for these things:
1.) Bad diode(s) in the alternator - one or more diodes have open circuited and are causing the voltage to drop off as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
2.) The secondary power ground is between the back of the intake manifold and the driver's side firewall. It is often missing or loose. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges. Do the voltage drop test as shown in the Fluke tech note link. Measure the voltage drop between the alternator frame and the battery negative post. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
3.) Bad regulator that does not increase field current as load increases. Remove the alternator and bench test it to confirm or deny this as being the problem.
4.) Bad sense wire - open circuit in sense wiring or high resistance. The yellow/white wire is the voltage sense and power for the field. There is a fuse link embedded in the wiring where it connects to the black/orange wiring that can open up and cause problems. Disconnect the battery negative cable from the battery: this will keep you from making sparks when you do the next step. Then disconnect the yellow/white wire at the alternator and the green fuse link at the starter solenoid/starter relay. Measure the resistance between the alternator end of the yellow/white wire and the green fuse link: you should see less than 1 ohm. Reconnect all the wires when you have completed this step.
5.) Bad power feed wiring from the alternator. Use caution in the next step, since you will need to do it with everything powered up and the engine running. You are going to do the Fluke voltage drop tests on the power feed wiring, fuse links and associated parts. Connect one DMM lead to the battery side of the starter solenoid/starter relay. Carefully probe the backside of the black/orange wire connector where it plugs into the alternator. With the engine off, you should see very little voltage. Start the engine and increase the load on the electrical system. Watch for an increase in drop as the load increases. Use the Fluke voltage drop figures as guidelines for your decisions.
attachment.php
It's on the back of the cluster, almost dead center in the middle. Use an ohmmeter to check it out. While you are at it, check the resistance on the wiring to the alternator green wirer and the cluster connections.
I don't recommend replacing it just because you don't know what else to do. The copper film used instead of a circuit board looks like it would be hard to solder and easy to damage.
not charging
you need a "Tuff Stuff Performance" 1 wire 140 amp alt & new tuff stuff mini starter(high torque) new "tuff stuff water pump (flows up 2 30% more. Remove all factory wiring harness (you'll never need it again).
one wire alt - summit racing (Tuff Stuff Peformance) is the way to go period......Quallity...easy install...remove old wiring harness - you'll never need it again.....
I was using a powermaster 1 wire and it finally burnt out. I bought a PA Performance 130 Amp, with just one wire hooked up it didnt work either, I needed a 1 wire regulator adapter. I would suspect a broken wire or bad ground in your case. Great information above J but its only if your using the stock 3 wire, what about when using 1 wire? How do you trouble shoot it then?
Hey, guys I know this is a dead post. But I am hoping if you can tell me one little thing. My alternator stopped charging after I removed my stock instrument cluster and installed aftermarket gauges. Is there a link or something on the cluster that closes the alternator circuit allowing it to maintain the battery? I ask because I found the diagram and don't completely understand it. My knowledge is limited of such things. This is on an 87 mustang lx with 5.0 and a oreilly alternator #01-0195.
Look carefully at the diagram an take notice of the green/red wire that connects to the regulator. It is part of the dash wiring for the alternator warning light. It is probably disconnected somewhere
Alternator troubleshooting for 86-93 5.0 Mustangs:
Revised 15 April 2012 to add simple check for regulator failure in Engine off ignition on, battery fully charged section, item 2.
Red color text applies to cars with a 3G alternator.
Simple first step: Remove the alternator and take it to your local auto parts store. They can bench test it for free.
Use a safety pin to pierce and probe the insulated connectors from the rear when doing tests with the connector plugged into its' mating connector.
Engine off, ignition on, battery fully charged:
Probe the green/red wire from the rear of the connector and use the battery negative post as a ground. You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed voltage regulator. This is an actual measurement taken from a car with a working electrical system. If you see full or almost full12 volts, the regulator has failed.
Familiarize yourself with the following application note from Fluke: See http://assets.fluke.com/appnotes/automotive/beatbook.pdf for help for help troubleshooting voltage drops across connections and components. .
attachment.php
attachment.php
Voltage drops should not exceed the following:
200 mV Wire or cable
300 mV Switch
100 mV Ground
0 mV to <50 mV Sensor Connections
0.0V bolt together connections
Alternator wiring circuit
Notice the green wire connects to a switched power source. The circuit contains a 500 ohm resistor in series between the switched power and the alternator. Connecting it to switched power keeps the regulator from drawing current when the engine is not running. The resistor limits the current flowing through the wire so that a fuse isn't needed if the wire shorts to ground.
Also notice the sense wire connects to the starter solenoid and it is fused. It connects to the starter solenoid so that it can "sense" the voltage drop across the output wiring from the alternator.
Replacement parts:
14 gauge fuse link for stock alternator.
Bussman BP/FL14 Fusible link
AutoZone
Dorman - Conduct-Tite 14 Gauge Fusible Link Wire Part No. 85620
Advance auto parts #85620
Pep Boys - SKU #8637594
I followed the tests until #2, green/red voltage with the connector plugged in, then you said:
"You should see 2.4-2.6 volts. No voltage and the previous tests passed, you have a failed voltage regulator."
I got 1.5 volts, I take that's also a fail?
Thanks for this awesome writeup, BTW!
It is time to pull the alternator off and take it to the auto parts store. They will test it for free. Have them test the replacement alternator before you go out the door if you buy a replacement from them.
