1995 302 Bock in a 1987
1995 302 Block in a 1987 Mustang GT
Hello,
I understand over the years the 302 motor has changed. Does anyone know the key differences in a 87-93 302 block compaired to a 1994-1995 block?
I have a 1995 block and am wondering if I rebuilt the short block would I be able to direct swap the shortblock to 87-93 Mustang. Basically will the 87-93 heads, water pump, brackets/pulleys, and intake bolt right up to the 94-95 block? If not I would have to swap everything out in the engine compartment to 1995...heads, intake, pulleys, etc.
Thanks,
1966 Mustang GT Fastback
1993 Mustang Cobra #4518
Major differences are:
- Hypereutectic pistons
- Timing cover
- Water pump
Dimensions, bolt patterns, etc are identical to the '87-'93. Install the pre-'94 timing cover and water pump, and it should work OK.
