  • 1994 - 1995 Specific Tech
1995 cobra cylinder heads
  • Thread starter Thread starter KasperG
  • Start date Start date Jun 21, 2008
KasperG
38
  • Jun 21, 2008
I have a 1995 cobra that is stock outside of exhaust and a msd billet dizzy. It also has a Procharger p600b with an intercooler that I have yet to run. I am trying to make up my mind on cylinder heads. Is it possible for me to make 450 rwh running the stock gt40 heads, and the stock cobra cam with the right dyno tune? If not, what would be the easiest way to get there? I would like to push 10 pounds of boost. Should I pull the motor and install a main stud girdle? Should I stud the heads as well?
1995greenstang
89
  • Jun 21, 2008
i dont know about making that much power with 10psi with stock heads have them ported and polished maybe 14 psi boost close to those numbers the studs would just be insurance that your not changing the head gaskets so ya its worth it
KasperG
38
  • Jun 21, 2008
Thanks, I am going to have a scuff and buff on the heads. Even If i could get at least 400 at the rear wheels I would be happy.
blksn955.o
3,263
st.louis mo 314
Jun 21, 2008
  • Jun 21, 2008
I know of a local guy with a lot of bolt ons and 13-15lbs that put down like 415-425 rwhp. Other than a gt40 intake the longblock was stock IIRC...with E7's.
I think it is possible but you will probably need a little more boost to reach that goal.
Venom351R
4,548
41
98
MAINE
Jun 21, 2008
  • Jun 21, 2008
Do a H/C/I Swap and you will be over 400 and close to 500 depending on how much boost. 10 PSI will get you close to 500 RWHP if you do the H/C/I
earleys94gt
1,223
Ashley, Ohio
Jun 21, 2008
  • Jun 21, 2008
You might be able to get there with the heads, but I don't know about the cam.
I would say to just replace the cam, but then you might as well do the heads and intake while you were in there.
You could do a H/C/I, then sell the Cobra stuff. Peeps are always looking to get Cobra parts.
Pokageek
2,767
MA, USA
Jun 21, 2008
  • Jun 21, 2008
That's all good advice guys..and he's gonna have a beast there but ... is;t tht a timebomb waiting?
KasperG
38
  • Jun 22, 2008
If I was to do the H/C/I swap. How much could I possibly get for selling the cobra heads intake, injectors, cam and rockers from my engine? Im just trying to figure out if I should do this right the first time or run with the blower until something gives. But If i do that and say something goes boom then I might not be able to sell this stuff. It is all a toss up. Also, Do i have to use a fmu and timing retard box if I get a custom dyno tune?
Thanks for all your help guys.
earleys94gt
1,223
Ashley, Ohio
Jun 23, 2008
  • Jun 23, 2008
I would say 500-600 for the heads, depending on condition.
Maybe 300 or so for Intake.
75-100 for cam, 200-250 for whole valvetrain.
50-75 for Injectors.
Nobody jump my stuff here, as I am not claiming to be an expert on pricing. Just trying to help out.
Why not do it right the first time?
I don't believe in buying/rebuilding parts twice.
FlyBy763
439
Palm Bay, FL
Jun 23, 2008
#10
  • Jun 23, 2008
  • #10
From what I have seen in my search for a decent set of GT40s...they usually go for around 400 bucks...
KasperG
38
#11
  • Jun 23, 2008
  • #11
Thank You for all your help. I think that I will sell my heads, cam and injectors. Pull the motor and get a forged bottom end. Then I will pick up a set of better heads like AFRs or victor jr.s Top this off with the common goods and call it a day. It will take me way longer but I see the benefit. I don't want to sell my cobra intake because I feel like I should keep it with the car. I went through the same problem on my lt1. The build turned out to be very expensive but well worth it.
cobra259
152
Waterford Mi
Jun 25, 2008
#12
  • Jun 25, 2008
  • #12
Look @ my Sig. It should tell you a few things. The 427 is with only 8lbs of boost. A VERY safe tune as well.
hope this helps.
WHITE94COBRA
816
HUNTINGTON BEACH
Jun 25, 2008
#13
  • Jun 25, 2008
  • #13
I'll tell you exactly how much I got for my stock stuff:
Heads I got $325 The rockers I sold to the same guy as well as the pushrods and lifters for another $100, I had an E cam so I got $125 for it, my timing chain and gears I got $25, the intake was $250 (ported). I sold it pretty cheap because I just wanted to get rid of it quick.
FlyBy763
439
Palm Bay, FL
Jun 25, 2008
#14
  • Jun 25, 2008
  • #14
Damn, I wish I could find somebody selling at that price now!
rj95svt
422
Hayden, AL
Jun 26, 2008
#15
  • Jun 26, 2008
  • #15
There is no real need to tear the motor apart unless your going to use a aftermarket block. The stock block is the real weakpoint and will split most times before the rest of the engine gives up.
With 10lbs of boost the stock h/c/i should be in the 370-400 range. There is one person on this site running a stock longblock with unported gt40 heads with a custom cam making 500+rwhp in a 94 cobra
Black95GTS
1,644
Marlborough, MA
Jun 26, 2008
#16
  • Jun 26, 2008
  • #16
If you're gonna get a whole new bottom end, time to look at stroker kits.
I think if you did a 5 angle valve job on the heads, ported the upper and lower, ran a methanol injection kit, bought 42# injectors, a new MAF, a new fuel pump, and got a quality tune, you could reach your goal for less bucks. You don't need to go forged for that kind of horse power as the block typically will break before the stock bottom end.
Just an idea.
Adam
Killercanary
The car that set the bar.
Altoona, PA
Jun 26, 2008
#17
  • Jun 26, 2008
  • #17
Look up GMKILLR here. He's making over 500rwhp with stock GT40iron heads (with upgraded valve springs). He doesn't have power steering and is running a decent amount of boost, but I think your goal is obtainable with what you have now as long as you add all of the other supporting hardware.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jun 26, 2008
#18
  • Jun 26, 2008
  • #18
I would install some AFR's to get maximum power. The GT40's are good, but you are gonna need the best to get 450RWHP.
I had a HCI 95 GT with a P600B and a 3 core intercooler with the 3" piping. The car only had 3.08 gears and it was a vert so I ran a 13.31#113.5MPH. The MPH tells me I was pushing 380-400RWHP. This was all with ABOUT 11.5-12LBS boost.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
