1995 vs 1990 (EEC-V vs EEC-IV)
  • Thread starter Thread starter cwtoyota
  • Start date Start date Sep 21, 2009
cwtoyota
21
Port Orchard, WA
Sep 21, 2009
  • Sep 21, 2009
I have a strong running 1995 GT convertable. It is a 5 speed car.
I wrecked that car (icy roads) a few years ago.
I have the EEC-IV (A9L tag) computer from a 1990 GT 5 speed car.
I plan to put the 1995 drivetrain into a 1989 notch. this car has no harness or electronics of any kind.
If I purchase the M-12071-C302 wiring harness from Ford racing, what needs to be done to make my 1995 EEC-V engine run with the EEC-IV box?
Will the 1995 engine harness work?
Will the 1995 sensors work?
will the 1995 injectors, etc work?
I'm no stranger to changing some connectors, or rewiring things. I've just never worked on the EEC-V cars, just driven this one.
Thanks in advance!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 21, 2009
  • Sep 21, 2009
The 95 sensors and injectors should be a direct swap. Reports that I have heard say that the 95 engine mounted fuel injector harness is not compatible.
Here's a helpful web site to check for wiring information...
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 21, 2009
  • Sep 21, 2009
1995 is also EEC-IV, but the harness is a bit different due to things like electronic transmission and fan controls.
Chrome_Rust
530
Findlay, Ohio
Sep 22, 2009
  • Sep 22, 2009
1995 fords are both OBDII and OBDI. If you look under the dash you will find a OBDII port, but the engine codes are pulled from the EEC test port in the engine bay near where the fuel lines come through. I just went through this on a 95GT...
BlownFiveLiter
18
108
Chicagoland
Sep 23, 2009
  • Sep 23, 2009
The OBD II port on a 95 is non-functional if it's a V8 car. Only the V6 models were OBD II, otherwise, it uses the same EEC test port under the hood on the GT/Cobra.
cwtoyota
21
Port Orchard, WA
Sep 23, 2009
  • Sep 23, 2009
Thanks for your help and the links to the wiring diagrams guys!
When looking through some of my Ford parts I found an injector harness on one of my intakes. It's an older 86-88 one, but it's in good shape.
I will try to set up the 1995 engine and sensors with that 86-88 injector harness, the M-12071-C302 main harness and the 1990 (A9L) computer.
Does that sound like a workable setup to you guys? Any big hurdles I should consider for that setup?
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • dan50
  • Jul 18, 2026
dan50
F
Electrical Car dosen't run without jumping the EEC IV test port
  • Fox2newedge
  • Feb 14, 2024
  • 2 3 4
9K
Fox 5.0 Mustang Tech Mar 15, 2024
Mustang5L5
J
Engine No power after idle
  • JustinTilley86
  • Aug 10, 2024
3K
Fox 5.0 Mustang Tech Sep 23, 2024
General karthief
