1997 351w swap?
  • Thread starter Thread starter stangman67
  • Start date Start date Feb 14, 2007
stangman67
294
connecticut
Feb 14, 2007
  • Feb 14, 2007
Good evening,
I am asking if anyone has experience with using a late model roller 5.8L into our early cars. Im trying to decide if i can use the short block with a cam swap and my edelbrock heads.
What is the engine balance (0, 28, 50 oz), can i use my early timing cover and 1 piece fuel pump eccentric? Also, what is the stock piston material and compression ratio. Im interested in just using the short block, i found one in great shape, and id like to use my current sfi balancer and billet flywheel.
Are there any other issues with my idea? THanks for your experience and help!
Mike
rhyno9
209
Oswego Illinnoying
Feb 15, 2007
  • Feb 15, 2007
stangman67 said:
Good evening,
Mike
All factory 351's use 28 oz balance factor. Heads will bolt on but you need to check piston to valve clearance especially since you doing a cam swap as well. It's a roller block so you have lots of cam choices. Timing cover should bolt up but you need to match the water pump's outlet to the cover because of the timing pointer. Pistons are gonna be cast or possibly hypers. It's a truck shortblock so the comp ratio is low 9's high 8's but that's hard to say because it really depends on the heads you are using.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
