1998 4.6 dies when hot
str8illone
Ok...I have a 98 4.6 and after I drive it for about 20-30 minutes the car will die acting like it runs out of gas and wont restart for around 20-30 mins., if I try to restart the car right after it dies it will run poorly for a split second. The MIL (check engine) light does not come on and there are no codes being set at this time. I have checked the fuel pressure and that is good. I have replaced the CKP because it was cheap and easy, and still have the same problem. I took a look at all of the TSB's and found nothing. Does anybody have some ideas?
I had a similar problem back in one of my old fox body Mustangs. It was the alternator to battery cable. It took me months trying to figure it out. I did a PA performance alternator swap which required upgrading the wiring. The old one was very brittle, and after the change, never had another problem. So check out the electrical side...my guess anyways.
