1999 Cobra Oil Cooler
Detroit Stang
14
I have a 1999 Cobra, and it has developed a leak from the oil cooler. I traced it to a small hole in the bottom of the part. So I bought a new part, but I see the same hole in the bottom of it. It looks like a weep hole or something. Can anyone tell me what this hole is for? Will I have the same issue with the brand new part?
Thanks so much for the help!
Are you sure that its coming out of that particular spot, there is a gasket between the engine block that can leak coolant, at least on the gt that is. If that's the issue use the new part anyway, if you can change the gasket your self that is. If not then return the part.
