  • SN95 4.6L Mustang Tech
1999 Expedition engine
  • Thread starter Thread starter mrmhrm9598
  • Start date Start date May 10, 2010
mrmhrm9598
58
  • May 10, 2010
I found a buddy with a 1999 4.6 out of an expedition. The motor is complete with a bad bottom end. I plan on doing a build on the engine so I am not worried about the bottom. My question is this a P.I. motor. He said it is a windsor and the oil fill neck is on the passengers side. the motor is complete oil pan to upper intake. I can get it for $100 so I don't want it to slip away if it is a P.I. setup.
mrmhrm9598
58
  • May 10, 2010
Surely with all of the knowledge on this site someone can answer this for me.
nancygrl
257
May 11, 2010
  • May 11, 2010
From what I've read in other posts, is that the Windsor has the oil fill on the passenger side, and that the Romeo has it on the driver's side. Also the Windsor should have more valve cover bolts 13 on driver's side and 14 on passenger side, and the Romeo's have 11 on both sides.
Almost all motors '99>up were PI head motors if Windsors. The Romeo's seemed to have switched a little later (2000 or 2001).
mrmhrm9598
58
  • May 11, 2010
So this would definitely be worth $100 bucks.
nancygrl
257
May 11, 2010
  • May 11, 2010
IMHO for $100 Yes. Worse case, if you tear it down you can probably make your $100 back and then some.
mrmhrm9598
58
  • May 11, 2010
Can I swap the heads and all upper parts onto my non pi engine in my 97 gt? I could then build my block while still having a little more power with the head and intake swap. I know that the 99 expedition was rated at 220hp and the mustangs at 260. Is just the cams?
midnightdriver
443
Northern California
May 11, 2010
  • May 11, 2010
Correct me if wrong, but I think the HP rating had to do with the ECU tuning as well as the intake manifold. The expedition needs more torque then HP due to its weight, therefore the engine is tuned that way. I think the cams are the same but that's taking a guess.
mrmhrm9598
58
  • May 11, 2010
So I will need a tune for best results. I have no idea where I can get a tune around here. I live in southwest Va. and there isnt much here. I can probably take it to Kingsport Tn. Any idea what a tune usually costs?
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
