2.3 t5 on a 302???
  • Thread starter Thread starter smuj_2006
  • Start date Start date Sep 27, 2008
smuj_2006
  • Sep 27, 2008
is it possible to put a 2.3 t5 behind a 302? i was told that all you had to do was swap out bellhousings. is this true? thanks.
cenok is family
1,409
69
79
Norman, Ok
Sep 27, 2008
  • Sep 27, 2008
and pilot bearing. i don't remember which one it is exactly, something from like an 80's ranger. the snout on the input shaft is a smaller diameter. i had a 4 banger t5 in my car for a while. first gear is usually 3.97 so if you have any sort of gearing in the rear, your first gear is going to be rediculously useless. i had that with my 4.10's...it sucked balls. but yes it works fine.
vristang
4,933
101
124
Seattle
Sep 27, 2008
  • Sep 27, 2008
If you already have a t5 mounted to your 302, then you already have the right bellhousing...
cenok is family
1,409
69
79
Norman, Ok
Sep 27, 2008
  • Sep 27, 2008
you know, that's what i've always thought, and i still actually think that. but i had a weird occurance when i was rebuilding my motor. i used the bell that came with the 4 banger t5. after i had everything together, i was trying to rotate my motor by hand to set my rockers, and it wouldn't turn at all! turns out it was because my flywheel was catching on something inside the bell! i was freaking out thinking something inside the motor wasn't right, so i started taking everything off backwards in order that i had just put it together, and when i got the bell off, the motor would rotate just fine. so i switched it out to one of my other t5 bells and everything was good after that. i dunno what was up, they look the EXACT same.
vristang
4,933
101
124
Seattle
Sep 27, 2008
  • Sep 27, 2008
How did you get a 4 cyl bellhousing to bolt up to a 302 in the first place?
The blocks have different bolt patterns, correct?
Beasty306GT
671
Oxford,Mass
Sep 27, 2008
  • Sep 27, 2008
Wouldnt the 5.0 blow that tranny up
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Sep 27, 2008
  • Sep 27, 2008
no they are just as strong, I dont care what they are rated for..
the gear ratios in it make for a fun ride though..
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Sep 27, 2008
  • Sep 27, 2008
only thing you have to replace is the pilot bearing, ive done it they hold up fine, you just spin alot more lol..
vristang
4,933
101
124
Seattle
Sep 27, 2008
  • Sep 27, 2008
I agree completely...
A buddy of mine ran a 4banger t5 behind his healthy 306 for about a year.
I bought the trans when he pulled it, so I could use in for a rebuild in a transmission class I was taking.
That t5 was still usable... and in fact I still keep it in the garage as a backup/spare.
jason
smuj_2006
#10
  • Sep 27, 2008
  • #10
what pilot bearing do i need then?
vristang
4,933
101
124
Seattle
Sep 27, 2008
#11
  • Sep 27, 2008
  • #11
If you measure the ID of the crank, and the OD of the trans input you can take those specs to NAPA, or another parts store to look up the appropriate part.
The part has been provided here before...
cenok is family
1,409
69
79
Norman, Ok
Sep 27, 2008
#12
  • Sep 27, 2008
  • #12
yeah they are different. the bell was a v8 bell is what i'm getting at. but it was "smaller" on the inside causing my flywheel to seize against it. that's what has me confused.
90blacknight
136
Sep 28, 2008
#13
  • Sep 28, 2008
  • #13
Great for burnouts
L
lang williams
567
cleveland, oh
Sep 28, 2008
#14
  • Sep 28, 2008
  • #14
i picked up a used t-5, fox bell housing, clutch fork, good clutch disk an pressure plate for $100. I was happy until I looked up the part number an saw it was a 2.3 T-5. I may try it now anyway. Just watching this hoping some one can list the throw out bearing number.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Sep 28, 2008
#15
  • Sep 28, 2008
  • #15
Technically no. They are made of the same materials as the V8 trans but are weaker due to gear ratios.
Steeper gears cause the torque rating to go down. It's just the physics of gearing.
They will hold up fine though if you drive it the right way. You can blow up a stock v8 t-5 with a stock motor and yet some guys have had 2.3L t-5's behind 300HP 5.0's with no prob.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Sep 28, 2008
#16
  • Sep 28, 2008
  • #16
4-banger bells won't bolt up to a 302. They don't even have the same appearance and a v-8 clutch fork and cable won't bolt up to it.
There are two V8 bellhousings through. The E3 bellhousing that came on 83-85's used with a 10" clutch and the E6 bellhousing used on 86-93's and uses the 10.5" clutch. When running a 10'5 clutch, it usuall contacts the E3 bellhousing and requires grinding to clearance it
L
LxVert
80
#17
  • Sep 28, 2008
  • #17
The pilot bearing that you need is p/n 14672 at AutoZone.
MAC'n89Blckstng
1,012
NJ
Sep 28, 2008
#18
  • Sep 28, 2008
  • #18
I ran a four banger t-5 in my car for a summer and it was awesome, I didn't even do the pilot bearing. Its now in my buddies and he beats the hell out of it. I think they are great for the money.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Sep 28, 2008
#19
  • Sep 28, 2008
  • #19
You gotta do the pilot bearing. The input shaft is a smaller diameter so without it the shaft will wobble with the clutch disk with it. You might get a vibration and the tip of the shaft will get chewed up
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
G
2.3 turbo question
  • Gibby8438
  • Apr 16, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 25, 2026
NXcoupe
N
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
