  • 2.3L (N/A & Turbo) Tech
2.3 turbo conversion
  • Thread starter Thread starter luvtruck
  • Start date Start date Oct 7, 2008
L
luvtruck
  • Oct 7, 2008
i am planning on building 2.3 turbo. Im planning on getting 400 hp First what size turbo would be the right size. second i am using the factory comp. (for now ) is there a way to change the air fuel ratio to be able to run E85 which is like 7.5:1
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Oct 8, 2008
  • Oct 8, 2008
You need more than just a bigger turbo to make 400 hp...to go that high you also need bigger injectors, and a standalone system or a custom tune for your computer.
And, you'd need even bigger injectors to run E85. By "Factory comp" I assume you mean factory computer....the computer "as is" can't run any bigger injectors than whatever it originally had (biggest injectors in a turbo car were 36 lb/hr). Again, you have to have a custom tune or standalone for bigger injectors.
Foxy_man
Columbus, IN
Oct 16, 2008
  • Oct 16, 2008
I'd be planning building a steel crank'd forged everything motor if you're looking at 400+
Standalone systems are pretty cheap, 200-300 bucks.
Don't put a huge turbo on it. Find a ct26 or something off of a supra, stuff a 61mm wheel in it and there's your quick spooling 400hp turbo.
550cc injectors, walbro 255 pump, and that's about it I think. BOV and IC are a given too.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
