Exhaust 2.5 Vs 3" Tail Pipes
2011rustang5o
113
As much as I love the sound of my long tube, o/r x dumped 40 series I'm a little over the exhaust smell at red lights and the wife is pissy. Need to add tail pipes. Any idea is there would be any real difference between 2.5" and 3" tail pipes besides sound? Everything else is 2.5"
331 stroker, heads, cam and intake 93 LX coupe car.
Sent from my iPhone using Tapatalk
My humble opinion.
Loud, annoyingly useless, with a drone at certain speeds that will drive you nuts.
But then my only experience was a big block chevell with full length headers H pipe borla mufflers and full exhaust, no it wasn't mine.
Thanks for adding nothing to this and not answering the question.
Sorry, from what I have read on here and a couple rags I get, a 3" exhaust is just loud, no real benefit, unless your putting out mad hp. Some tests even show loss of hp and or tq, you could keep the 3" to the mufflers and neck it down to 2.5" over the rear and out the back, mandrel bent of course, that will tame it a bit in my opinion, with minimal power loss, coups have an advantage over hatch backs on exhaust noise inside the car. Also the straight pipes that exit the back of lx cars should be the same size, some times exhaust shops but a 'polished' end that is bigger giving it a megaphone effect. Loud does not always sound good.
This is my opinion and only my opinion, I hope to be helpful, I am also a bit of a joker, so expect the occasional reference to beer and picking on priuses.
Reactions: 1990slow50H
I know on the 2011+ cars 3" is useless unless you are turbo and high numbers. I'd like to tame it down a little. 2.5" it is. Kinda thought the 3" looked good but it's hard to tell in a picture.
There is no horsepower benefit to going with 3" tails on your setup. The bigger tails will do little more than make your exhaust louder. A 2-1/2" exhaust will support over 450hp N/A.
Still gonna drone like a bugger with those 40-series on there. That's just the nature of a chambered muffler.
For the tailpipes only, no real benefit of 3" pipes over 2.5". Really just a visual thing.
3" might be a pain to run over the axle just for clearance, and usually the transition from 2.5" to 3" after the axle can look awkward if visible.
As for sound. You have a 331, it's gonna be loud no matter what.
Reactions: Davedacarpainter
Yea sound either way is ok with me. Loud or quieter it is what it is.
Not that I suggest it but 2 1/4" tailpipes would not loose any performance either. Reason being the exhaust gasses have cooled and contracted by the time they come out of the muffler. The contracted gasses don't need the same size pipe that's closer to the engine to flow the same amount.
Science! I almost bought a stock set of tail pipes BUT they are too far away for me to want to drive for them. Gonna order the 2.5" late model tail pipes. They got a 10% off sale right now.
I would probably buy a whole catback.
Last time I checked, the tailpipes were all over 50% of the cost.
Much easier to bolt in and adjust a catback than mix and match mufflers and hope it all fits without welding and cutting.
I switched to a dynomax ultraflo welded kit so my mm panhard bar fit without modifications to the pipes and I got it on sale on amazon for $259 for the whole thing and that was for the lx 2.5 setup.
If I did a cat back I would need a mid pipe to because the previous owner had bullet mufflers welded to the mid pipe. Not trying to spend a million dollars right now.
I bought a Flowmaster cat back for my LX. My stock LX tail pipes were in such good shape I chucked 'em behind the shed for another day. Later my son bought a 93 vert that had dumps off the mufflers. Warlock mufflers and man was it obnoxious riding in that thing. We went behind the shed and resurrected the old stock LX pipes and had a local street rod builder we know make an adapter and welded them on. Man what a world of difference adding tailpipes makes! 100% tolerable now! Even feels like it runs better without all the noise in the cabin.
My friends dad has a track only bracket racer nova. It's real neat to sit it in at idle and cruise it in the pits because it's open headers. So when I got this car I was psyched because it was like that kinda but the romance has already worn off. Especially because I think the dumps are 1/2 the reason the interior smells "old" even with the new carpet.
