2 coils not sparking
JoeyHemi
Texas
Sooooo, my 1 and 4 coils aren’t firing and I have changed the spark plugs, the spark plug wires, the coils, and the PCM. What is their left???
  • Sponsors(?)
wmburns
SN Certified Technician
Aug 14, 2009
5,807
499
164
Houston Texas
Just wondering. What model year Mustang are we dealing with? 1996-1998 (coil pack) or 1999-2004 (COP)?
Since you stated "spark plug wires" I'm going to assume this is a coil pack ignition system.
Confirm HOW you are testing for spark. With an external spark tester?
Are you absolutely positive that the correct plug wiring has been used? The correct cylinder to coil pack tower? The coil pack ignition is affected by spark plug wiring routing.
What have you done to rule out a problem with the signal return lines to the PCM? Have you tested for opens or short to ground?
V8 coil pack diagram
Thread starter Similar threads Forum Replies Date
J No spark from coil wire Fox 5.0 Mustang Tech 1
A Electrical No spark from coil Fox 5.0 Mustang Tech 1
T Electrical Cranks OK, but No Start 92 Mustang 5.0 Coil Fat Blue Spark per jrichker Fox 5.0 Mustang Tech 2
S 2006 Mustang GT Premium Spark plugs and coil packs 2005 - 2014 S-197 Mustang -General/Talk- 2
8 Electrical Intermittent Coil Spark - No Start. Fox 5.0 Mustang Tech 1
D Electrical Origin Of "fat Blue Spark" Referenced In Cranks Okay/no Start Checklist Fox 5.0 Mustang Tech 2
modulistic Weak Spark At Coil, No Spark At Plug Fox 5.0 Mustang Tech 14
S Blown Spark Plug Coil Nightmare SN95 4.6L Mustang Tech 2
85_SS_302_Coupe Heli-coil Spark Plug Threads, How Reliable? SN95 4.6L Mustang Tech 14
J 01 GT After changing spark plugs and coil packs, car started ticking/knocking, now it wont run. SN95 4.6L Mustang Tech 20
J Spark plug coil issue SN95 4.6L Mustang Tech 6
D Coil Packs, Spark Plugs and Wires SN95 4.6L Mustang Tech 3
G Weak spark of the coil Fox 5.0 Mustang Tech 7
B Low spark comming from coil Fox 5.0 Mustang Tech 2
M S197 4.6 Spark Plug and Coil Pack 2005 - 2009 Specific Tech 0
B 95 Mustang GT no spark from coil 1994 - 1995 Specific Tech 3
AnthonyR23 Intermittent Spark - Coil to Distributor Fox 5.0 Mustang Tech 18
Adam95GT More Electrical HELP! No injector pulse, no spark from coil. 1994 - 1995 Specific Tech 3
R weak spark number one tower on the coil pack SN95 4.6L Mustang Tech 1
H no spark frm coil but power to coil Fox 5.0 Mustang Tech 5
Aliate X Cranks, No start, Orange spark @ coil....? Fox 5.0 Mustang Tech 32
rcuriel coil and spark plugs wires question 1996 - 2004 SN95 Mustang -General/Talk- 2
M Barely to no spark at coil 1994 - 1995 Specific Tech 13
B Ignition Coil Sparking? Fox 5.0 Mustang Tech 6
F no spark at coil Fox 5.0 Mustang Tech 1
T HELP no spark off coil!! Fox 5.0 Mustang Tech 25
1Bad88notch spark coming out the side of coil Fox 5.0 Mustang Tech 0
brentwoodboy Misifire, Oil On #6 Coil Pack and Spark Plug... SN95 4.6L Mustang Tech 3
donkey_punch spark @ coil wire but not @ sparkplug wire? 1994 - 1995 Specific Tech 13
donkey_punch spark @ coil wire but not @ sparkplug wire? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
fox racer coil doesnt spark, where to look? Fox 5.0 Mustang Tech 8
wms004 Stripped a "Coil On Plug" Bolt while changing spark plugs (Part # for the bolt??) SN95 4.6L Mustang Tech 3
N Noobie questions, Please dont laugh. Ignition coil & Spark Plugs Fox 5.0 Mustang Tech 10
B need help bad!! STILL no spark to coil!!! Fox 5.0 Mustang Tech 22
B STILL can't get car started!! (no spark to coil) Fox 5.0 Mustang Tech 10
B please help can't get spark to coil!!! Fox 5.0 Mustang Tech 10
Crs Msd blaster coil getting no spark! Classic Mustang Specific Tech 4
wildmandave no spark-good coil 95 cobra 1994 - 1995 Specific Tech 16
wildmandave good coil, no spark- what gives? SVT Tech Forum 1
N coil sparking??? Fox 5.0 Mustang Tech 1
astronut1885 Please help. No spark to coil, tried everything! Fox 5.0 Mustang Tech 26
Max Power No spark from coil.. Classic Mustang Specific Tech 13
MyCARneedsHelp No spark from coil 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
MyCARneedsHelp No spark from coil Fox 5.0 Mustang Tech 13
M Gaping spark plugs for new coil packs SN95 4.6L Mustang Tech 1
2 anybody running a 96 to 98 Gt with a screaming demon coil set up ?? NOS/ spark plug?? SN95 4.6L Mustang Tech 0
S No spark from my ignition coil?!?! 1994 - 1995 Specific Tech 6
OonDeanisS spark plug coil wire question Fox 5.0 Mustang Tech 5
YadiStang Low voltage at coil - after trying to start the motor? 1965 - 1973 Classic Mustangs -General/Talk- 1
ppost Coil over kits 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
