.2 over bore 4.6 2v here.
BlackPony4.6
Morris CT
Hey guys, as you can see I am new to the whole forum page thing here. I am currently building a turbo 2v and im looking for some help. The turbo kit will be a on3 performance 70mm turbo kit. It is a windsor block bored .20 with all manely bottom end. I am getting trick flow heads and am completely lost on what cam to run. I know that piston to valve clearance can be an issue with these things but these heads are supposed to help with that issue. an recommendations on what cams to run??? Please help.
I would choose a reputable brand and call the manufacturer of your turbo kit to see what cam they suggest. The I would call the company of the cams your buying and ask them for input on your setup with the turbo. Most of the time certain blower/turbo setups require specific cams for proper compression/combustion. This is what I'd do if I was in your shoes. You might want to post in the tech forum on this site for further help.
