Fox 200 Amp Alternator
92NOTCH01
Well-Known Member
May 14, 2016
188
96
63
I tried to search it couldn't find anything regarding
A 200 amp alternator. Is anyone running one? If so what brand? I found PA Performance on the the internet but it's close to 400 bucks, anything cheaper?
Thanks in advance.
Sent from my iPhone using Tapatalk
Do you need 200 amps? There are a ton of 140 and 160 amp units that practically drop in.
I was just trying to do the max I guess u could say.
I figure I'm putting the AC back in, electric radiator fan, stereo system, etc. I wanted to get the most possible.
Unless you are running some sort of crazy stereo setup, no real need to go beyond 130a.
Even 110A would be plenty.
The shortcomings of the stock mustang alt isn't that it doesn't have enough current draw (granted it needs more than 75A when you add things like e-fan) it's that it doesn't make proper voltage at low rpm.
A 130A 3G or 6G is all you need. Most modern cars with all the bells and whistles don't have much higher than that
Sent from my big ass iPhone 6 using Tapatalk
Reactions: Davedacarpainter
