200 cubic inch swap???
  • Thread starter Thread starter BarryB
  • Start date Start date Mar 22, 2004
BarryB
KY
Mar 22, 2004
  • Mar 22, 2004
I have a 67 convertible with a 200 ci engine. I bought it from my uncle who bought it new. In the last 20 years I have put less than 500 miles on it. Recently I have been interested in getting it running again. The motor is practically shot. How many other Ford models could I find that have a 200 ci motor that could be swapped out? My Stang has a 3speed tranny in the floor but I wouldn't mind switching to automatic. Can you guys name some compatible Fords that would be easy to swap motors and trans from? I am good friends with a local auto salvage dealer. Thanks a lot for any info you can give me.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Mar 22, 2004
  • Mar 22, 2004
Falcons, Comets, Mavericks, Mustangs, Broncos (early generation), Econoline vans (again early versions). The Mustangs last used this engine about 1982.
TheWolf
257
NC
Mar 22, 2004
  • Mar 22, 2004
200's were used in Falcons, Mustangs, Mavericks, Comets, Fairlanes, probably a lot more and lasted from 1965-1983. The 200 came on the market in 65 and few changes were made until 1980 I believe when they went to a low mount starter (matchs v8 bolt patterns). The motors after 1980 won't work with your transmission without modifacation. All things considered I believe a '78 model 200 from a say Maverick is your best bet. Stock, engines after '78 had the largest intake valves (the cr was lowered on these engines but can easily be milled back up) and had a duraspark II system (both the head and distributer are interchangable for all 200s)
red65
411
Ann Arbor, MI
Mar 22, 2004
  • Mar 22, 2004
I've got a 200 w/ auto that I recently pulled from a '65 - needs refreshing but ran well. PM me if you're interested in talking.
rbohm
6,698
550
204
tucson,az
Mar 22, 2004
  • Mar 22, 2004
be carefull when selecting a late model 200 as some used a different bolt pattern than the early blocks. you want to find the high mount starter block as they will bolt in to your stang. if you find a 200 with a low mount starter, then you will need to get the tranny as well.
TheWolf
257
NC
Mar 22, 2004
  • Mar 22, 2004
Yea, that started in 80 for a 200, 250s always had those.
68rustang
1,537
Cleveland, OH
Mar 22, 2004
  • Mar 22, 2004
why not get the existing engine rebuilt?
BarryB
KY
Mar 22, 2004
  • Mar 22, 2004
The motor has been rebuilt 3 times. My uncle bought it new and wasn't very gentle with it. The tranny is almost shot too. I thought it would be easier and cheaper to find a car with matching motor and transmission and swap them out. If I find one with an automatic transmission, how much trouble will there be changing from manual to automatic? Will an automatic fit where the manual was?
rbohm
6,698
550
204
tucson,az
Mar 22, 2004
  • Mar 22, 2004
yes but the 200 and 250 bells wont swap with out minor modification.
TheWolf
257
NC
Mar 22, 2004
#10
  • Mar 22, 2004
  • #10
I thought I said that, maybe not in so many words
Anyway,
Sure an auto will fit where a manual was. As long as you got everything from the donor car, it shouldn't be much trouble. Avoid the early 2spd autos.
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
05-09 mustang motor swap
  • 3vgabe
  • Feb 25, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Feb 26, 2025
3vgabe
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 4:28 AM
2v_johnny
