2000 Explorer 5.0 block vs. other 5.0 blocks
  • Thread starter Thread starter ford_thoroughbred
  • Start date Start date Jan 29, 2012
First Prev 2 of 2
ryan ward
Lewis, Iowa
Feb 17, 2012
#21
  • Feb 17, 2012
  • #21
what is diff about the cam
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 17, 2012
#22
  • Feb 17, 2012
  • #22
The Explorer cam is ground to produce more power and torque at lower RPM. Sounds good, till you realize it also falls off much sooner in the power band as well. Great for pulling a trailer....not so good for going fast. Because of it's tamer profiles, the Explorer engine also utilizes weaker valve springs. Go with the HO cam, or better and you'll overpower those springs in a hurry.
ryan ward
Lewis, Iowa
Feb 17, 2012
#23
  • Feb 17, 2012
  • #23
ok so all you have to do is change from the factory cam or will it be that way with all cams
ryan ward
Lewis, Iowa
Feb 17, 2012
#24
  • Feb 17, 2012
  • #24
with rebuilt heads with better springs
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 18, 2012
#25
  • Feb 18, 2012
  • #25
Swap the HO cam into the Exlporer long block, along with an upgraded set of valve springs and you're good to go. Instant '93 Cobra engine.
ryan ward
Lewis, Iowa
Feb 18, 2012
#26
  • Feb 18, 2012
  • #26
ok sweet just bought a motor like this for $400
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 18, 2012
#27
  • Feb 18, 2012
  • #27
Good deal. Now tear those heads and intake off and have them ported and polished, then put something nastier in there than the stock HO grind and really burn some rubber.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Feb 18, 2012
#28
  • Feb 18, 2012
  • #28
My buddy Keith just got done doing exactly that, and I helped him install Trick Flow's spring kit. Maybe he can step in here and give you some advice, too. 94stangfan
79'293stang
505
11
29
Cedar Rapids, Iowa
Feb 18, 2012
#29
  • Feb 18, 2012
  • #29
I will give another thumbs up for the trickflow spring set, I have been running them for 20k and no issues. On another note, I would not sweat the hyper pistons, I've been boosting on them for 20k and not a light 20k either.
I did however at one time spend 3k on a all forged assembly and then the block broke ruining my uber expensive rotating assembly. Last time I will ever spend any money on a rotating assembly for a stock block 302.
rdharper02
like kicking myself in the junk
703
237
84
Feb 18, 2012
#30
  • Feb 18, 2012
  • #30
I will second 79'293stang, I ran 10lbs on hypers for a few years prior to removing the turbo for another car. It was tuned conservatively, but I ran it hard. Hyper pistons tend to get a bad rap due to the fact that the do poorly with detonation. No piston really does, but hyper pistons can actually reach a resonant frequency that causes them to shatter.
Rick 91GT
Mustang Master
95
99
PA
Feb 19, 2012
#31
  • Feb 19, 2012
  • #31
What trickflow spring are you putting in? Stock retainers/locks?
79'293stang
505
11
29
Cedar Rapids, Iowa
Feb 19, 2012
#32
  • Feb 19, 2012
  • #32
Trickflow spring set comes with new locks, retainers, shims, height measurement tool and valve seals.
Rick 91GT
Mustang Master
95
99
PA
Feb 19, 2012
#33
  • Feb 19, 2012
  • #33
So its the kit that is made for their heads...ok I know which one.
1fast302
10
Michigan
Feb 28, 2012
#34
  • Feb 28, 2012
  • #34
When using the Trick Flow valve spring kit on GT 40's, is there anything special that needs to be done?
79'293stang
505
11
29
Cedar Rapids, Iowa
Feb 28, 2012
#35
  • Feb 28, 2012
  • #35
Nothing special is necessary. The kit comes with shims, just use the measuring tool that is supplied in the kit to verify install height and use shims as appropriate. It is very straight forward, took me about 2 hours to install on the car.
94stangfan
290
Indianapolis, IN
Mar 6, 2012
#36
  • Mar 6, 2012
  • #36
Sorry about the late start on the comment thread. I really recommend the trick flow kit. So far everything has been good valve spring wise. It also comes with everything that you need to do the install including new valve seals. If you price it out, there isn't a better deal on this stuff either. All you need outside of their kit is a valve spring compressor. Some string/rope to hold the valves up and that is pretty much it.
94stangfan
290
Indianapolis, IN
Mar 6, 2012
#37
  • Mar 6, 2012
  • #37
Check out my blog, I just did this entire swap. http://www.nerdawg.com
Foxslider
im not that much of a idiot
Oct 25, 2019
543
156
53
Houston, TX
Dec 31, 2019
#38
  • Dec 31, 2019
  • #38
I can do the search, but anyone know what blocks are all the same off top. Like 90-94? Compression is the same? If im going this route, i should just get this block, and port these heads gt40p's vs. these E7's also. Well... Ima do my top end on this block, then if still burning oil (it will be), gonna junkyard explorer block it. And i wont feel bad for beating the living hell out of it. After i break this one. lol It prob won't break less i ultra dog it trying to break it. But the oil consumption is annoying, lack of compression on a cylinder or 2, power robbing.
First Prev 2 of 2
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
Fox Cobra wheels real vs. replicas
  • keel
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Monday at 8:52 AM
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
