2000 GT - 04 Crown Vic Swap
So I bought a 2000 mustang gt 4.6 manual trans with a bad motor after reading some posts saying that a swap would be fairly simple and now I'm running into a problem with finding a fly wheel for it the donor motor is coming from a 04 crown vic and the flex plate is a 6 bolt the fly wheel that was with the old motor is a 6 bolt . Dose any one have a part number for one that will work ? Tia
Try this. Go to car-part.com and search for a flywheel from a 2001 Mustang GT. This will get you a 6 bolt flywheel set up for an 11" clutch.
Should you wish to have a 10.5" clutch then search for a flywheel from a 1996-1998 Mustang GT.
Reactions: Chase.stough
