B banks98stang Member Nov 20, 2009 57 0 6 Jan 31, 2012 #1 Jan 31, 2012 #1 ok we n just bought some 19" wheels n put them on my brother was driving n his abs light came on any reason why? thanks
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,535 21,704 234 Box behind Walmart Jan 31, 2012 #2 Jan 31, 2012 #2 Yes... because something is not working right. Pull the wheels, clean off the sensor pickups (they probably got something on them while you were swapping wheels). If that doesn't work then pull codes and let us know.
mransr Founding Member Nov 3, 2000 1,188 36 98 Riverside, SoCal Jan 31, 2012 #3 Jan 31, 2012 #3 may be an obvious question...but did you put 19" wheels on all four corners? an excessive tire diameter difference will kick on the ABS light
trombonedemon Well-Known Member Jun 25, 2009 1,962 39 59 U.S.A, U.S.A., U.S.A.! Feb 1, 2012 #4 Feb 1, 2012 #4 mransr said: may be an obvious question...but did you put 19" wheels on all four corners? an excessive tire diameter difference will kick on the ABS light Click to expand... You beat me to it.
B banks98stang Member Nov 20, 2009 57 0 6 Feb 1, 2012 #5 Feb 1, 2012 #5 yes mransr said: may be an obvious question...but did you put 19" wheels on all four corners? an excessive tire diameter difference will kick on the ABS light Click to expand...
evolucion311 Member Mar 19, 2009 236 2 18 Feb 6, 2012 #6 Feb 6, 2012 #6 You need to tune the computer with the new tire size and ratio. If you are unable to communicate with the ABS computer at all then the control module is fried and you'll have to replace it. Lucky for you I made a video describing how to do such a thing. Search my user name on youtube and you'll find it.
1fun281 Member Mar 16, 2009 438 8 19 Atlanta Georgia Feb 6, 2012 #7 Feb 6, 2012 #7 Unplug the ABS fuse... Easy fix
