2000 Mustang Gt Passenger Valve Cover Help
Foursixxx
Im replacing the valve cover gasket only , i put rtv on the end of the head and time cover . The only problem i have is putting on the valve cover , gasket keeps falling off any tips?
Yes. You haven't installed the gasket under the valve cover grommets.
There's a tab on the gasket around each bolt hole. When the gasket is fully inserted at each bolt hole these tabs will grip the metal part of the grommet spacer.
Reactions: robertsa
Ohh ok i will check it out when i get home from work thanks for the help .
