Expired 2001 Cobra 63k Miles
Beautiful low mileage driver! PM for more info.​
Mileage as of 01.13.13 63531Miles​
New Full Length Cobra Headers and hardware (Note: Engine has to be removed to accomplish the installation)
New BBK Off-Road ‘X’ Pipe
New Oxygen Sensors with extended leads
Flow Master Series Mufflers, Bansanni SS from Muffler back and Big Mouth Tips.
Trans Painted the same color as the top half of the Cobra
New Center-Force Pressure Plate with Dual friction Clutch, Roller Pilot bearing with Rear Main Seal, clevis pin and Fork while the Transmission was down.
New Steda Clutch Quadrant and Cable with Tension adjuster at the Fire Wall
New Battery, Irridum Plugs, Fluids changed
New MTX Powered Subwoofer in the Trunk
Front Clip, Lower valence and Fog Lamps are 2004 all OEM
Custom 3 Coats of Paint with 6 coats of NEXIA 643 Clear Wet Sanded Buffed
Valve Covers as well as the Cross Over are Painted to Match the Car Top
ECM/ECU Flashed with the Latest Updates
Tinted Headlight assemblies in the Trunk – 5 Minute Swap time Clear to Tint
GPS Tracking Device in Passenger Side Kick Panel, is not activated
Have documentation for the parts purchased and installed
BBK Cold Air Induction Kit
Cobra 01 -07.webp Cobra 01 -10.webp Cobra 01 -13.webp Cobra 01 -15.webp Cobra 01 -17.webp
