2001 Continental Engine -> Foxbody
  • Thread starter Thread starter RyanEllis
  • Start date Start date May 31, 2014
R
RyanEllis
  • May 31, 2014
I found a 2001 32 v engine (fwd) can it be put into my 87 Gt
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
May 31, 2014
  • May 31, 2014
Intake and accessories all have to be changed. Which wouldn't be a big deal, except that I'm pretty sure it's only got 1 motor mount
R
RyanEllis
  • May 31, 2014
The engine much diff than the rwd version? I can get excessories and computer And everything from the continental
tannerc91gt
2,967
234
Indiana
May 31, 2014
  • May 31, 2014
I'm pretty sure you cannot use it as it's built to be mounted FWD as such the motor mount design doesn't fit like a standard mod motor. Which is enough of a project in itself.
tannerc91gt
2,967
234
Indiana
May 31, 2014
  • May 31, 2014
Let me correct that,
I would bet it's a Windsor block like anything else. I see that you'd probably have to drill and tap the motor mount holes on whatever side doesn't have it. The accessories and oil filter and all those things will be weird. Oil pan too I imagine. I know the intakes are different and the coil packs.
It CAN be done from everything I see, but I'd hope you were getting the motor really cheap to be worth it
http://forums.corral.net/forums/gt-sohc/95394-lincoln-intech-32v-engine-what.html
Here's a bunch of info
stykthyn
5,232
2,652
223
gainesville
May 31, 2014
  • May 31, 2014
It can also be tied to a chain and used as a boat anchor. That engine would be a horrible choice for a Fox.
Reactions: revhead347
R
RyanEllis
  • May 31, 2014
Thanks a lot for the info! Yeah i wS def getting it cheap and low granny miles. Seems like it would be a huge headache even if it is possible haha
R
RyanEllis
  • May 31, 2014
What would you recommend then, besides 351
stykthyn
5,232
2,652
223
gainesville
May 31, 2014
  • May 31, 2014
What do you plan on using the car for? What motor does it currently have?
R
RyanEllis
#10
  • May 31, 2014
  • #10
Very tired stock 302. Most street use
stykthyn
5,232
2,652
223
gainesville
May 31, 2014
#11
  • May 31, 2014
  • #11
Gt40 engine from 302 explorer/mountaineer. Swap cam and a couple other parts it's a solid 60hp over the stock 302 and it bolts right in.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 31, 2014
#12
  • May 31, 2014
  • #12
^^^^ this x 5
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
May 31, 2014
#13
  • May 31, 2014
  • #13
You cannot use the FWD continental engine.
The block is different from the RWD version of the 4.6L 32v. It will not work in a RWD application.
Toss it in a 2000's Taurus
tannerc91gt
2,967
234
Indiana
May 31, 2014
#14
  • May 31, 2014
  • #14
Odd that ford made a separate casting for that. I've seen people say they have done it. But while anythings possible, it seems far from practical
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
May 31, 2014
#15
  • May 31, 2014
  • #15
Sure they weren't referring to using a Mark 8 engine? Usually most Lincoln 32V swaps use this.
TOOLOW91
20+ Year Stangneter
8,763
234
S.I.NY
May 31, 2014
#16
  • May 31, 2014
  • #16
Better question here is how big is your buget followed by your goals to give an accurate answer
tannerc91gt
2,967
234
Indiana
May 31, 2014
#17
  • May 31, 2014
  • #17
Not that it's definitive proof or any thing
R
RyanEllis
#18
  • Jun 2, 2014
  • #18
I found an 2000/2001 explorer with 5.0 that i can get for cheap. This be suitable? Will my 87 computer and efi work with it with no problems
R
RyanEllis
#19
  • Jun 2, 2014
  • #19
And what about bolting up to my tranny
stykthyn
5,232
2,652
223
gainesville
Jun 2, 2014
#20
  • Jun 2, 2014
  • #20
Yes. Swap cam, distributor, upgrade valve springs, oil filter adapter, all the front dress from your old engine and you are ready to rock. It will bolt up to the t5 or the aod.
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
3.27 to 3.73 worth it? (Automatic)
  • skidad
  • Nov 4, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 5, 2026
nickyb
A
GT ABS Module in a 2001 Cobra
  • Aamer309
  • Oct 17, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 3, 2026
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
