2001 Spindles on my '87, what does it take to fit?
Fox and SN95 tie rod ends have different threads, so they are not interchangable. I asked Matt90GT about that also when I was doing my conversion. I have a stock 87 style rack and 87 tie rods, but I am using 95 spindles. Mine work fine. I don't know for sure, but you might be able to use the newer rack and tie rods?
sleeper89 said:
94-95 are the ones you want. ;)
-steve
Yes those are the years needed to maintain stock track width. The 96+ will widen out the front stance by about 1/4" on either side.
And yes they will bolt right up. You'll have some wicked toe in when you connect the tie rods and you'll have to adjust them by eye so you can hobble to the nearest alignment place but other than that they work fine.
