2001 V6 Windstar Swap...done With Issues
Try this. Cycle the key on/pause/off several times without cranking. Listen for the fuel pump to run each time. Does this improve starting? If so, consider fuel pressure leak down causing the difficult re-starting.
there is only one problem with your theory.....i never removed the fuel rail or anything fuel related and i drove the car into the garage and 1 hour later was done.....thats when its started this
So I guess this means you won't be doing a 30 second test to confirm one way or the other. Since you are so sure this isn't a fuel pressure issue, then this leaves:
  • Vacuum leak.
  • Black vented IAC not opening to allow starting air to enter.
  • Different CAM and CKP sensor correlation set up between the model years.
  • Different coil pack design.
  • Different fuel injectors between the two model years.
  • Lazy intake air flow during cranking. Are the IMRC held fully open?
  • Base engine.
Good luck.
