  • SN95 4.6L Mustang Tech
2002 GT manual transmission help.
  • Thread starter Thread starter Jester67
  • Start date Start date Oct 15, 2007
Jester67
908
TN
Oct 15, 2007
  • Oct 15, 2007
My Brother just bought a new 2002 GT with a five speed and was hoping that you guys could help me out. What manual trans came in these cars it kind of looks like a T5 but then again it does not. Also how do you get replacement gear oil in to the trans? The fill plug is in the tail shaft and above the cross member support any trick would be a great help.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Oct 15, 2007
  • Oct 15, 2007
you have a tremec 3650.
i believe the 3650 uses atf rather than gear oil. i may be wrong since its been a while since i had the stock tranny in my car.
M
mjh78
22
  • Oct 15, 2007
Refer to your owner's manual. My 00 GT calls for the 80-90 Gear Oil PLUS the friction modifier. I got both from the ford dealer. The gearbox uses ATF. I paid $25 (labor) to have all my tranny fluid changed, but if you want to do it yourself, I believe you'll need a pump to pump the gear oil up to the fill hole.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Oct 15, 2007
  • Oct 15, 2007
2000 and 2002 have different trannys. and may take different filids. be sure before you change it!
lvmustanggt
721
Las Vegas
Oct 15, 2007
  • Oct 15, 2007
I got 2002 mustang gt and it's got 3650. I use Royal Purple Max ATF 4 qt
Jester67
908
TN
Oct 15, 2007
  • Oct 15, 2007
We where going to replace it with Mobil 1 synthetic ATF fluid but could not figure out an easy way to do it without a pump. I will rig up a positive pressure system to get in. Thanks for the help.
Is the 3650 a good tranny I know the T5 is a popular swap into the classics but have never heard of a 3650?
C
Coreyned
45
  • Oct 15, 2007
discount auto parts has a pump that screws onto a quart of fluid, cheap plastic thing and only couple bucks, it works
Jester67
908
TN
Oct 15, 2007
  • Oct 15, 2007
we looked for something like that but could only find them for gallon bottles
Mach1Run
333
Wylie, Texas
Oct 15, 2007
  • Oct 15, 2007
When I had a 3650 the way I refilled it was to remove the shifter base from the top of the tranny and pour it in there.
T
Two Wheel Peel
94
PA
Oct 15, 2007
#10
  • Oct 15, 2007
  • #10
Sometime in the winter of 2001 they switched from the T-45 tranny to the 3650. You should have the 3650.
I had synthetic oil put in my T45 and highly reccomend it to everyone. It goes into gear smoother even when it's cold out.
katshot
17
Dover, DE.
Oct 25, 2007
#11
  • Oct 25, 2007
  • #11
The recommended fluid is Dextron III and the fill is 3 liters (that's about 3.3qts I believe). They came with a factory fill of Mobil 1 but SHOULD NOT be using that. Synthetic is not recommended from what I understand.
Superhereaux
chicks make me feel inadequate
538
South Texas
Oct 25, 2007
#12
  • Oct 25, 2007
  • #12
hit the nail on the head
after COUNTLESS threads about the 3650 this is the general consensus. i used 3.3 qts. of Castrol Domestic Vehicle ATF (mercon/dexron III) in my 'o2 when i swapped in my MGW and it works great
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
6G alternator pigtail wiring help needed
  • Dogman_1969
  • Aug 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 11, 2025
Dogman_1969
D
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
