2003/04 Cobra Block Special?
tjm73
2,418
Rush, NY
Is the block (just the block, not the internals) special? Or did the just use the iron Mustang GT block or truck block? Did it get any kind of special machining for the front cover or anything else?
i've heard two sides to this one and i dont know for sure... i know the 99 was the teksid aluminum block, the 01 was another aluminum block... but if i am not mistaken i've read several places that the 03/04 cobra block was iron.... this does not go hand in hand with the standard cobra being a aluminum block... but then again its the first cobra with a blower. I'l take a look around and see if i can track down the answer, if someone else does not get here first.
Torinalth
ok, the 03/04 cobra block is iron... was done because of heat issues of the aluminum block affecting the heat induction of the blower.... anyhow... the cobra block is iron for the terminator, however the front cover is different as it is for all cobras compared to GT... what exactly i do not know.... i also know there are a few holes that are not the same for the heads from gt to cobra iron block... i cant recall which ones.. but there are other subtle differences... ironically the cobra block for the 03 is 1500 while te GT is 450.... kinda amusing...
what reason do you have for this question?
Torinalth
Torinalth
Just trying to gain knowledge for possible future projects.
I kinda wanna build a drag car out of my daily driver 98 GT in a couple years and my current idea is a big bore 5.0 DOHC carburated modular engine. I want to go carb because I want to play with the mod motor but don't want the expense of the EFI system and it's related hardware. With the right internal parts and a NOS system I think as much as 700-800 hp is possible on a budget.
the front cover was different to allow for the duel serpentine belt design on the 03/04s. if you look you will notice that the accessories are farther forward and the waterpump i sbehind the accessories with its own belt.
as for going carbed i think thats one of the most moronic ideas i have ever heard in my life. that is unless the car will be a track only car. if you plan on driving it on the street i hope you know that the carbed motor will be completely illegal anywhere in the US. you cant have a carb'd motor on a 96+ car legally in the US. plus it would cost more for a carb setup than an EFI setup.
one of your first considerations would be wether to go with an aluminum or an iron block. if you go aluminum, you might as well go with the 96-99 cobra Teksid aluminum block. it is the strongest aluminum block ford made, and it will not crack down the centre like the 01 cobra "explorer" block.
if you want to go iron, then definately get an 03/04 cobra block. however, if you want to go with a 5.4 motor, then look at getting a 03+ F150 block.
I was thinking race only. I have no plans for it to be a street car with this setup. Though a T-bucket street rod with this engine would be cool. :rolleyes: Hmmmmm......
Your tech info it seems to be top notch. Thanks. Can the '99+ DOHC heads be bolted on the early aluminum blocks without any special work? I have such a lack of knowledge about the DOHC/SOHC interchangeability it isn't even funny. :nonono:
I had never heard that the early Aluminum blocks were the toughest aluminum blocks made. Are they stronger than the iron blocks? For example.... take 2 identical NOS engines, will the iron block take more power or less or the same?
The iron block will be the strongest, but at a weight cost. The Teksid italian block is the shat if you can get your hands on one. Teksid also makes the blocks for Ferrari......
Yeah the weight pennalty is a given.
What is the difference in bare blocks anyway?
as dan said the iron block as a whole is stronger... however the teksid block as i mentioned earlier (standard on the 99 cobra) is the strongest block made to date for ford... many used to well over 1000HP, however iron can do that too.... the 01 cobra block was not made using the same design and thus is not nearly as strong, but will take 500-600 without too much issue... around 800 with some heat and people have seen the block split at the water jacket.
for the power you are wanting i would get VT engines involved... get the BB stroker 324 on a teksid block, use the FR500 DOHC heads ported with some nice cams and you will have a disgusting NA block... spray down 200-300 and you will be fine up around 600+.
the carb idea, while interesting will be more hastle then its worth... issue being is that the computer controls so much, you cant just unplug it... bypassing it has proven equally as dificult, but there are a select few items that have done it... I hear Karkraft is doing it for their cyclone engine, a modular carb engine.
people are making very high numbers with computer control EFI and not having issues... personaly, if you think that EFI will be a hangup then i suggest you do some more research.
2v to 4v is not really that hard... from what i understand there is a hole that needs to be plugged, and another opened for i believe coolant to interchange heads... and i think romeo heads are the only ones that can be changed to DOHC... or was it windsor.... cant remember... but there are few issues, but there none the less...
Torinalth
I guess I don't see the hassle. If you strip the engine of all computer controls, add a carberator and a stand alone ignition system that's not computer controlled, what does anything related to the computer have to do with anything?
I don't think EFI is a hang up I think it's needlessly expensive for what I'm thinking about.
Sullivan Intake $600
Demon Carb $500
TEC-II Distributorless Ignition $600
That's cheap.
yeah, but when the computer no longer has control it starts to get unhappy... i cant remember who tried it a while back on modular depot... but someone did something similar and had all sorts of issues that you'd think would not be allocated with the ignition and fuel alone.... i dont have first hand experience of course... just know someone has done it and reported weird occurances that have no relation.... never saw if he got it fixed or if he went back to computer control...
as far as expensive... that 1100 for the carb and ignition alone would pay for even the most expensive of tune software that lets you control everything yourself. I'd say go carb if you really want to do it different. just trying to let you know that computer control will work fine as well and possibly with less money and headaches. either way works, just take your path and run with it :)
Torinalth
