  • SVT Tech Forum
2003 Cobra 1st Gear Problem
  • Thread starter Thread starter Ferris Bueller
  • Start date Start date Jul 5, 2008
F
Ferris Bueller
21
MD
Jul 5, 2008
  • Jul 5, 2008
Just picked up a 2003 Cobra today with 12k miles on it. During the test drive(s) the transmission shifted fine without any problems. After taking it home and driving it easy around town, I noticed that I could not get it into 1st gear when at a full stop. I could get it in after shifting to other gears first, but it doesn't feel like it should. It goes into 1st smoothly if i'm moving slowly, but once I stop it's a pain. Please help! Am I looking at a clutch cable adjustment issue, or an expensive T-56 repair? Thanks Stangnet.
F
Ferris Bueller
21
MD
Jul 6, 2008
  • Jul 6, 2008
As far as I can tell, I have the stock clutch/quadrant/adjuster.
After driving some more, I thought the clutch wasnt disengaging fully. I tried pulling up on the clutch pedal to adjust, but it never clicked. I had to manually ratchet the adjuster to get more slack. Now everything shifts fine and the clutch engages higher up.
'94ChickStang
301
northern ca
Jul 18, 2008
  • Jul 18, 2008
you shouldn't shift any car into first without being at a full stop, bad for the tranny. Probably good that it doesn't let you!
T
TheDukeOfEarl
127
  • Jul 18, 2008
And you base this info on what? 1st doesn't have different synchro's.
It is a fairly common issue with the T56 to not want to go into 1st at a stop. Its the same for the vipers and vettes. When you are sitting you can either double clutch or just do a quick 2nd then 1st to rotate the shaft a little. It tends to get worse when hot. When my trans fluid is at 240 or hotter its really hard to get 1st.
MarcMonteverde
66
S@c-ToWn
Aug 4, 2008
  • Aug 4, 2008
if it has a 12k mile go to the dealership and tell them to fix that ****!
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
2008 Mustang Bullitt stuck in Fifth gear
  • Jester67
  • Jul 15, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 27, 2026
Jester67
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
  • SVT Tech Forum
