Suspension 2003 Mustang Gt Convertible Suspension Change
Addam Cox
CA
Hello,
I was looking to lower my GT 1 and a half to 2 inches. It has all stock suspension parts still on it. What is a good lowering suspension part list and what will I need to do it, struts, caster camber plates, etc. I have been looking at some eibach springs, but do you need to install the caster camber plate amd tie rods when only lowering up to 2 inches? Also, I am looking to upgrade to 18 inch tires soon also. Any help would be appreciated, I need it lowered.Thanks for the help.
New struts at a minimum. If you lower 1.5 to two inches the caster camber plates (go with Maximum Motorsports) are a must as well. Unless the tie rods are bad I wouldn't worry about them. Eibach is a good brand. Steeda is good too. Stay away form the ebay el cheapo stuff.
