2004 mystichrome cobra for sale
walker95svt
69
Abilene, TX
Well, I just bought it and my life has taken a turn for the worst. After buying it/inspecting it myself, it went to nextgen motorsports in Hayward, CA for another inspection there and it's checked out mechanically solid. It's also the prettiest mystichrome I've ever seen, and I was shopping for a while. Of note are the seat and steering wheel inserts, which are great and unrubbed off. Most mystichromes over 15-20k lose the steering wheels inserts, it's like the shine gets rubbed off or something. Anyway, I'll take 26K for it. It's been modded, and what's been done has been WELL done and detailed.
Here's the full mods list:
Borla catback exhaust with polished tips
2.8 inch grooved/notched pulley with matching belt and aftermarket tensioners
cold air intake
T-56 magnum transmission
maximum motorsports front suspension
-front coil overs
-maximum motorsports K-member (drastically reduces front suspension weight and improves handling)
-drilled and slotted front rotors w/fresh pads
-maximum motorsports caster chamber plates
Solid rear axle
lower control arms with adjustable spring perches
welded axle tubes
31 spline strange rear axles
aftermarket rear diff (fully streetable)
3.55 gears
eibach springs
upper control arm relocation bracket with adjustable upper control arms
strange rear shocks
-differential brace/cover
aluminum driveshaft
front sway bar
rear sway bar
fully welded and reinforced frame:
- full length welded and detailed subframe connectors
- welded and detailed driveshaft loop
- welded and detailed torque boxes
- Full welded roll cage with removable door bars (they'll come with the car)
- full racing harness
SVT interceptor multi-function digital gauge (can read and display most car parameters)
Boost gauge
dash mounted gauge pods
Chrome 18" (original, not knockoff) ford 2000 Cobra R wheels. They have ford part numbers on the inside, and ford logos.
Brand new high-performance tires
