  • SN95 V6 Mustang Tech
2004 v6 Mustang: Max A/C Issue.
  • Thread starter Thread starter nickheffner
  • Start date Start date Sep 13, 2010
N
nickheffner
  • Sep 13, 2010
I am having some issues with my wifes v6 04 mustang. She reported she started smelling a burning smell on the way to work this morning while the A/C was set to Max. The air flow was very low accompanied by the smell. When she switched it to regular A/C the burning smell dissipated and the airflow for that setting was correct. I havent had a chance to look at it yet but figured I would check in here. I leave for a business trip in the morning so its going to be an all nighter to fix it if possible. We live in Texas and she would murder me otherwise
I know the A/C on regular pulls air from outside the cabin and Max A/C circulates air from inside the car. Is there an easy way to get to the venting system from inside the cabin to see if anything is lodged in the intake? A little bit of a car repair noob but the internet hasnt failed me yet. Thanks all!!! Will report back with my findings.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 13, 2010
  • Sep 13, 2010
OK, let's see if I can answer some of your questions. The AC heating system is very difficult to access behind the dash. For repairs of anything beyond the bottom of the ducting, requires the dash to be removed.
Is it possible that a foreign object has gotten in? I once had a car that I swore smelt like oak burning when the AC was started. When I finally got around to fixing it, I found that the blower motor was overheating. As I got into the job, I found the cowling covered with oak leaves. The leaves entered the system and got into the blower. Add heat, and get a burning oak smell.
Could the burning smell be anti-freeze?
If this were my car, I would take a look at is the blower motor resister. It is located at the bottom of the passenger side (right hand) duct work (near the glove box). Possible there is contamination on the element. Check for water or anti-freeze (heater core leak).
Next, look at the blower motor itself.
While there, check that the dampers move as expected. Switch to defrost mode, does the air re-direct to the windsheild? If not, look at the vacuum line from the engine bay through the firewall.
Anyway, that should give you something to start with. Good luck.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
N
2008 V6 Mustang Won’t Cold Start
  • nraffy13
  • Nov 17, 2020
2K
2005 - 2014 S-197 Mustang -General/Talk- Nov 17, 2020
nraffy13
N
M
I really wasn't expecting this....... First time Mustang owner.......
  • Mikedd969
  • Nov 27, 2019
3K
1996 - 2004 SN95 Mustang -General/Talk- Nov 28, 2019
Mikedd969
M
For Sale 193 Original Miles on this RARE Barn Find 1989 Ford Mustang LX 5.0 Convertible
  • EarnhartBuilt
  • Dec 16, 2019
8K
Fox Body Mustangs For Sale (1979-93) Jul 27, 2023
Blueinfan
A
1995 Mustang Cobra Radiator Fan operating only when A/C is on AND only for a few seconds!
  • Alfadragon17
  • Jul 31, 2019
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Aug 18, 2019
HISSIN50
