Suspension 2005 GT Left (driver side) tire wobbles, most noticeable on right turns. With front end jacked, more free play on left than right.
dan diego
San Diego
My driver side tire wobbles, most noticeable on right turns. With front end jacked, there is definitely more free play on left (drivers side) than right wheel with hands checking for play at 9 and 3 o'clock. I am unsure if right side is excessive but definitely feel that driver side is problem. I have replaced inner and outer tie rods, front wheel bearings, front sway bar links, front sway bar bushings. The excessive play remains. Struts are ~4 years old.
Looking under the inner tie rod boot, I can see the free play goes into the rack and pinion. I do not know what is too much and what is normal. I have a video if this helps.
View: https://www.youtube.com/watch?v=W69lgfc9IKc
Dan
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
35,730
11,715
224
Massachusetts
If it's the rack, you should have the same play on both sides.
I had the same issue on my DD. I could have sworn it was the rack due to seeing the same thing, but it was one side only. On further investigation, my tie rod end (which only had 500 miles on it) was bad. Because it was brand new, I assumed it was fine. It was not.
dan diego
San Diego
Thanks for the reply. I am right there with you. I cannot think that anything in the rack and pinion or upstream would not have the same symptoms at each wheel. As for the inner tie rod, I had the same suspicion. I recently changed out my new tie rods, inner and outer, with newer and better quality inner and outer tie rods. The problem persists.
dan diego
San Diego
Wanted to put a capstone on this thread. Unable to solve on my own, I took it to a professional mechanic. Problem was control arm ball joint. Replaced each side, control arm w/ ball joint, and my problem was solved.
Reactions: 1 user
Mustang5L5
Mod Dude
Feb 18, 2001
35,730
11,715
224
Massachusetts
It’s funny how these issues manifest as movement in the steering rack. I was certain my rack was faulty due to the same movement, and it ended up being something else
glad you found it
