2005 P0128
Good morning! This code popped up.
Coolant was topped off. Is there a way to bleed it?
Most of my research points that if this does not cure it, I should change the thermostat, but it could be the temp sensor.
I appreciate anyone's input on how to further diagnose this issue.
Thanks!
Sounds like a stuck/sticky thermostat. Not sure bout stangs, had to replace one on a mazda cx7 recently. It was a two man job but easy enough and the mustang's engine bay is much more spacious.
Also at least on a cx7 stuck thermo means engine runs too lean so get it replaced sooner rather than later.
