2006 Convertible top rebuild
phwsman
Kentucky
More out of necessity than choice (some fool removed the lift motor but left the lines) I am restoring a "manual" (which I'm pretty sure means no motor and either no pins and/or no lifts) to a "power" top
I got the replacement motor and it works fine. I got the "lower" line screwed into the motor fine
The "raise" line however has a screwdown nut that will not turn.
Is there an adaptor I can buy that would tighten down on the line and then plug into the motor and tighten down on it?
The lines work fine so it seems like a waste of $100 to buy new ones
Thanks in advance
