- Oct 31, 2017
- 1
- 1
- 1
I have a 2006 Mustang GT Convertible. The top will not go up or down. When the try lower it the windows all go down then nothing. If I touch the down button again I hear a click from the engine relay box and then clicks for each rear side window.
I checked the following items:
verified relays 31 & 33 both click when power is applied. And an Ohm test to verify voltage.
verified fuse 13 & 51 are both good.
I removed the pump and plugged it into my friends 2007 Mustang Convt. and the motor spun.
I check the switch on each side of the rear by pressing on them with a small screw driver while attempting to lower/raise the top.
But still nothing bu clicks when I press the top button.
Please please help.
Also, if I did any of these steps wrong or incomplete that would helpful as well.
Side note I bought a refurbed pump assy as well and it does the same thing.
Please please help.
