2006 Power Window
Fred1845
When I close drivers side door window goes almost all the way down by itself.window will go all the way up when door is open,but when I close door it is hitting frame of window.Is window off track? It isn't hitting rubber,but plastic surrounding door.Is it fixable?
With the window closed, hold the switch to put it down, and keep holding it for about ten or 15 seconds after it gets to the bottom. Then hold the switch up (Door closed) and when the window gets to the top, keep holding another 10 or 15 seconds.
Then check it out and let us know. That reprograms the stops.
racerraj,thanks for response,but it didn't work .Still goes down when it hits top of window frame................Looks like it is hitting hard plastic around window opening.Can it be off the track?Doesn't seem to be straining when it goes up or down .
