Engine 2008 stang gt lifter or rocker arm
Majestic_3v
Sacramento
Good evening guys thanks for accepting me to the group. I had a couple questions about my late Mustang. I’ve been trying to figure it out. I have checked the oil. I’ve checked the compression. I’ve checked the coolant. I open up the valve covers a check in sign I’m having kind of loud tick. Sounds like it’s coming from passenger side. If anyone has any suggestions or anyone had an experience with this. https://photos.app.goo.gl/k6DAdCccDVdzwJR79
Incoming Checklist! :D
️ S197 Mustang GT (4.6 3V) Tick Diagnosis Flow​
Step 1 — Baseline Check
  • Warm the engine to full operating temp.
  • Listen with the hood open.
  • Ask: Is the tick uniform across all cylinders?
    • Yes → likely injector tick (Step 2).
    • No (localized) → go to Step 3.
Step 2 — Rule Out Normal Injector Tick
  • Place a mechanic’s stethoscope or long screwdriver on the fuel rail/injectors.
  • Injector tick = rapid, consistent, metallic clicking, same rhythm across all.
  • If it’s clearly loudest at the injectors and uniform → normal injector tick. ✅
  • If not, continue to Step 3.
Step 3 — Isolate Accessories
  • Remove the serpentine belt.
  • Run the engine for 10–15 seconds max (no water pump).
  • If the tick disappears → it’s an accessory (idler pulley, alternator, A/C clutch). ✅
  • If it’s still there → go to Step 4.
Step 4 — Localize Tick to a Bank
  • Use stethoscope on each valve cover (front and rear).
  • If one bank is louder → suspect lash adjuster/follower on that side.
  • If both banks tick front-of-cover → suspect cam phasers.
Step 5 — Test Cam Phasers
  • With the engine idling hot, unplug both VCT solenoids (one per valve cover).
  • If tick changes, quiets, or goes awaycam phasers are the culprit. ✅
  • If tick remains unchanged → go to Step 6.
Step 6 — Lash Adjuster or Follower
  • If the noise is sharp, single-cylinder, and persistent hot/cold, suspect a lifter (lash adjuster) or roller follower.
  • This requires pulling the valve cover to inspect, but you can narrow it to a bank first with a stethoscope.
Step 7 — Consider Piston Slap (Rare)
  • If the tick is only on cold start and fades when warm, and stethoscope doesn’t show valvetrain/fuel, it could be piston slap or carbon buildup.
  • Usually harmless unless severe.
Quick Summary​
  • Uniform tick → injector tick (normal).
  • Tick disappears with belt off → accessory drive.
  • Tick changes with VCT unplugged → cam phasers.
  • Tick isolated to one bank → lash adjuster or roller follower.
  • Cold start only, fades warm → piston slap/carbon.
Reactions: Dino Dino Bambino
Quick Summary​
Oh my thank you so much. I’m gonna try all these steps first and make sure I think I’ve done a few of them already, but I’m definitely gonna go through this list. I will post the updates back here to see what I found. I posted it on Instagram, Facebook and TikTok and no one has had one response so thank you so much.
That cam follower looks bad and it's already started to eat into the cam lobe.
