2011 5.0 mustang manual brembo brake package !
drdenny,
No offence to Svtpilot but the e-brake is adjustable (in my 2012 and, I presume, the earlier and later models).
The e-brake adjustment is in the center console. Open the back hatch and on the lower left side you will see a rectangular cover plate. Carefully pull it off (don't drop it in the hole) and you'll see a threaded rod with a nut or two on it. Tighten the nut to reduce the slack in the cable.
HTH,
Chris
