Sponsored New Release: 2024+ S650 Brembo Rear Stainless Steel Braided Brake Lines
MRaburn
Founder
Admin Dude
334
174
Auburn, AL
Great news from J&M Products – we're launching our new direct-fit stainless steel braided brake line kit for the rear of 2024+ Ford Mustang S650 models with factory Brembo big brake package.
Key Benefits for Your Customers:
  • Reduced Line Expansion – PTFE inner liner + stainless braid for firmer, more consistent pedal feel under heavy rear braking
  • Direct OEM-Style Fit – Exact factory replication of fittings, brackets, and routing – true bolt-on, no adapters or modifications
  • Optimized Flex Length – OEM-spec fittings minimize braided section length vs. universal kits → quicker response and superior modulation
  • Designed for Brembo Big Brakes – 4-hose rear set engineered for Performance Pack models (GT, Dark Horse, etc.)
  • Superior Corrosion Resistance – Fittings with zinc nickel and trivalent zinc plating for maximum durability in harsh conditions
  • Abrasion-Protected – Black or clear cover to shield against debris, heat, and wear
  • DOT Certified & Pressure Tested – Individually tested for leak-free performance
  • Assembled in the USA – Premium quality with limited lifetime warranty
https://hotpart.com/product/2024-fo...d-brake-hose-kit-brembo-black-or-clear-cover/
