  • SN95 V6 Mustang Tech
20hp resistor
  • Thread starter Thread starter starterman
  • Start date Start date Sep 17, 2006
starterman
  • Sep 17, 2006
how do i hook up a 3.3ohms resistor for 20 more hp
How do i hook up a 3.3ohm resistor to get 20 more hp how does it work
V6muscle00
68
nj
Sep 19, 2006
  • Sep 19, 2006
idk the idea behind this but its probably a scam. im pretty sure resistors only keep current at a certain level within the car. for example a resistor determines how much current goes to an electric fan for different speeds like lo and high so idk what hp ud make off that
Give Me TP
936
Republic of Texas
Sep 20, 2006
  • Sep 20, 2006
If it involves the MAF sensor or it's wiring harness don't do it.....it's today's equivalent of snake oil
Skymarshal
572
Dallas
Sep 20, 2006
  • Sep 20, 2006
Just say no.
This "mod" involves putting the resistor on the air temperature sensor in the MAF housing, to fool it into thinking the air charge is much cooler than it is. This tells the computer that it can advance the timing a little to make more power, and richen the mixture to maintain the A/F ratio in the cold air.
It will make a little more power (maybe 5 HP) initially, but since the engine is running richer, your spark plugs will be getting fouled, your car will be blowing black smoke, and eventually your Check Engine light will be on, your car will be in the shop, and all the mechanics will be laughing at you!
trock
Mexico (Missouri)
Sep 20, 2006
  • Sep 20, 2006
This is a terrible idea. To do anything with a resistor you would have to solder it in, and probably somewhere in the wiring harness or chips or somewhere. If this were the case then a programmer would do the job. So spend the money if you really want to have horsepower. HP=MONEY so dont expect 20 hp from a 1 cent resistor. And yes they actually cost one cent.
V
v6stang8
  • Sep 30, 2006
my mustang is for sale im me and ill send pic's i'm asking $3,000 obo. it have a modeled tv in the dash new carpet, seats, headliner. pioneer cd player, sony 1000 watts amp. pioneer speaker in the door and back deck. the heads have been port and polished. k&n oil filter, high flow air filter. comes with a lot of extra parts
98CobraClone
592
Ripley, Ohio
Oct 16, 2006
  • Oct 16, 2006
IBTL!!!!!!!
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
9
1998 V6 - What is this line called?
  • 98_Stanger
  • Aug 10, 2025
SN95 V6 Mustang Tech Aug 10, 2025
nickyb
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
Computer repair advise
  • sammie9271
  • Jul 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2025
Parauno
P
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
