22 gallon fuel tank ????
sparx
369
I just read in a recent Mustang magazine that a 22 gallon fuel tank was available and sold by Virginia Classic for vintage Mustangs. It is a Scott Drake part.
Problem is I cannot find one anywhere...
sparx
The 22 gallon tank has been available since 1970. It's called a 1970 Mustang fuel tank. You must also use the 1970 fuel sending unit with it. With slight modification to your filler neck, it bolts right in.
This is the Scott Drake 22 gal tank, comes in steel or stainless (at twice the price):
You can save a little weight and trunk space by using a 69 tank (20 gal). I haven't done this, but I have heard you have to bend the fill port back to make it line up with the fill neck. This can be done by using a piece of 2" pipe as a lever.
OT, but I'd do this if I could figure out how to put the gas cap in the trunk. I'm tired of pouring gas on the ground every time I fill up. Nozzles in CA don't work on 67/8 cars!!! Rant over.
