I just got a new speedo cable and a 23 tooth gear because I have 4:10s, I know that my speedo still wont be right on but does anyone know how far it will be off? Its a 91 gt with a 5spd. Thanks guys!!!
The faster you are going, the further it's off (reading faster) At around 90, it told me I was going like 75-77MPH. I had my Dad follow me in his Chevy truck that time, so I know it's 100% accurate. At around 50MPH, I think it would read like 43-45MPH.
In stock form your '91 GT would have had a 3.08 rear end, the tranny will have an 8-tooth drivegear on the output shaft, and the speedo gear would have had 20 teeth.
With your mods, the speedo will be overreading by about 16%. If you replace your 8-tooth drivegear with a 7-tooth, the speedo error will be reduced to just 1%.
Is yours manual or automatic?
If the original axle gears were 2.73, the speedo gear would have been 18-tooth instead of 20. With a 4.10 axle gear and a 23-tooth speedo gear, the speedo will overread by 18%. The remedy is still the same. Replace the 8-tooth drivegear with a 7-tooth and the speedo error is reduced to just 3%.
