#24 injectors with speed density ? anyone
beaver2489
503
st. joseph missouri
anyone have bigger injectors with their speed density? I have a power managment system and AFPR so I could probably fix any lean/rich problems probably.... you think 24's will work ok? I tried converting to mass air but the wiring harness I got was from a newer (93+) mustang and I cant get the fuel pump to come on with it! SO I'm stuck with SD still, which is fine with me as long as I can keep the 24's I just installed. Thanks :flag:
no it wont work properly, you would be running rich as crap, because at the same pulse width of 19# , the 24# injecters would be spraying a whole lot more fuel.... you need to shorten the pulse width so you can use the 24# imjectors, meaning you probably have to reprogram the ECU.... and i dont see how that wiring harness doesnt work.... all you need to do is splice into power and ground....add two pins for the mass air, and move two pins for the thermactor.... viola you got mass air.... thats all i did couple days ago....
and you dont need a special tool to pull the pins out....i just gave em a good tug and they pop right out, and pop right back in (make sure that red pin locker is back in when your done) ...
i have an 87 with ported stock heads 1.9/1.6 with 1.6 rr and crower 15111 cam that has about the same lift duration as your cam that i run with 24# injectors @ 35 psi. runs great, but a little rich (slight gas smell) when idle drops below 1000 rpm. i am still working on tuning. it is not perfect, but the guy that ran the dyno said it had a better idle and relative hp/torque than most of the mass air cars with similar mods.
it works.
oh your working with the whole harness....hmmm i just grabbed the mass air plug and wires and fished them through the firewall... im using an A9S eec also.... i just didnt bother with the fuel pump voltage wire or the speed sensor, everything is well...
it works.
THANKS! thats what I wanted to hear lol. I'll still try to get my mass air conversion done today, but its nice to know that if I need to, I can just hook the SD stuff back up if I need to drive the car. Thanks man, I think my problem with the mass air conversion is that the wire harness is from a newer 93+ mustang and the fuel pump relay is different and I gotta change something around...
