24lb injectors
  • Thread starter Thread starter nickcasta
  • Start date Start date May 5, 2009
N
nickcasta
20
worcester ma
May 5, 2009
  • May 5, 2009
does anyone know how much more i can get out of 24lb injectors with the correct mass air for them over stock injectors? is it worth doing?
stykthyn
5,232
2,652
223
gainesville
May 5, 2009
  • May 5, 2009
if you are running over 300hp then yeah, you would benefit. if you are running a stock or close to stock set up then you wont notice any difference.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
May 5, 2009
  • May 5, 2009
What type of mods do you have done, or are you planning? On a stock engine, you'd see no benefit.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
May 5, 2009
  • May 5, 2009
Injectors don't make HP. They just give your engine more fuel so that your supporting engine modifications can perform to peak levels.
If you are near stock, your 19s are fine and going to 24's won't do anything.
If you are around or above 300HP, 24's will just allow you more fuel and give you a safety factor. You'll only see a bump in power if your 19's were starving your engine at that point
Dino Dino Bambino
1,673
90
79
Cyprus
May 6, 2009
  • May 6, 2009
This thread will answer your question:
http://forums.stangnet.com/784674-help-me-injector-size.html
Essentially you can keep the stock 19lb injectors, stock fuel pressure, and stock fuel pump if you haven't gone beyond basic bolt-on performance mods and still have stock H/C/I (270hp).
What mods do you have or plan to do?
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
