260 to 302 swap
  • Thread starter Thread starter ballajb64
  • Start date Start date Sep 11, 2006
ballajb64
76
California
Sep 11, 2006
  • Sep 11, 2006
i have a 1964 1/2 mustang with a 260v8 with a 3 speed manual transmission. i decided that i am goin to put in a 302 from a 87 highway patrol mustang. i decided to go with a carb instead fuel injection. and i also want to put a 5 speed manual in instead of the 3 speed. what are the things that i will have to do to get this to work?
Max Power
1,774
St Paul
Sep 11, 2006
  • Sep 11, 2006
Have you searched the archives? This has been discussed a lot over the years.
M
mustangman1974
463
  • Sep 11, 2006
Noting much if your changing the entire driveline. You will need to get a driveshaft made though. And you will also need the linkage, and trans mount. The engin bolt up to stock engine mounts. I would personally try a cable setup for the clutch, but then again I have only assisted in manual trans changes never planned one. I did the same swap but a 89 5.0 (better cam) and carbed it. I used the same transmission cept I changed the front bellhousing. to a 6 bolt. Eventually tore that one up though.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Sep 12, 2006
  • Sep 12, 2006
Do you need a new driveshaft on a 68 as well? Just curious, as I had contemplated a 5.0 in my 68 coupe.
T
tylerrocks
514
Big Spring, TX
Sep 12, 2006
  • Sep 12, 2006
I dont know about 68's but on my 260/3speed-to-302/5speed, I didn't need a new driveshaft. Just had my existing one shortened. I did have to get a new u-joint to fit the slip yolk.
Tyler
Jester67
908
TN
Sep 12, 2006
  • Sep 12, 2006
You have a 5.0 in there already 302=5.0 so if the motor is the only change that will be the only thing you will have to change.
CarFreakGT
20+ Year Stangneter
May 26, 2003
395
11
29
Louisville, KY
Sep 12, 2006
  • Sep 12, 2006
wasn't thinking. Thanks jester.
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
A
Resolved 302 still running after turning off ignition
  • AlexM556
  • Nov 14, 2026
Classic Mustang Specific Tech Nov 15, 2026
AlexM556
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
