26spline G-Force T-5 ? and Cam suggestions for N20..
ritc
40
I recently asked about a budget 11-12sec setup and been making a list im down to the a T-5 option when I blow my stock one and what cam to use with N20(150shot) and ported E7 heads(with explorer intake)?
I did some searching here and on google and found many people using a Comp Cam XE274 with N20, good specs?
As far as the G-Force question its more so I know what to start buying now and have ready for when I do have the $2,000 for a built G-Force T-5, now I know they come with 26spline compared to the stock 10spline, what do I need to complete the setup and where can I buy it from mostly?
So far I know I need a 26spline clutch disk while still maintaining a 10.5 surface not 11" like 94+ stangs, correct? Where would I buy this clutch setup or for what car? As far a driveshaft i've read that FMS Aluminum DS from a 94-95 stang would work, do I need anything else going into a rear end that will have a 31spline diff from a explorer?
Most of your major clutch manufactuers sell the 26spline disk, I just a spec stage 4 for my g force trans! 340$ to my door. Part number is SF484T , its a solid hub clutch though and is not the most street friendly thing in the world. But who cares! lol
Can you order it online from anywhere? Where did you get yours? Cause all I can find are spec I and II's for 86-95 stangs, what car would I look for if I wanted the 26spline? Or would I have to call everyone directly and tell them I want a 10.5" disk with a 26spline?
