2v 4.6 Power Limits?
  • Thread starter Thread starter 2vjordy
  • Start date Start date Jul 19, 2017
  • Tags Tags
    2v 4.6 power limits?
2vjordy
Active User
Jul 19, 2017
  • Jul 19, 2017
I have a 2002 mustang gt 2v and was wanting to do some engine work this winter..i was gonna put forged internals and twisted wedge top end kit and maybe 6 months later put a procharger...do you think the block could handle that power plus what hp range do you think I would be in
squeak93
2,332
409
164
Joplin, Missouri
Jul 19, 2017
  • Jul 19, 2017
The blocks handle 800rwhp easily. Use Arp hardware and don't look back. If you're wanting to run more find a Teksid (96-98 cobra and mark 8 blocks) or 03-04 cobra iron block (4 bolt mains). But the stock 2v block is strong, especially when comparing to a 302 block.
squeak93
2,332
409
164
Joplin, Missouri
Jul 19, 2017
  • Jul 19, 2017
To add to that, the stock 6 bolt cast crank is good to 800 all day long too. The teksid in the cobra and some other various models had an 8 bolt forged crank that is a lot stronger. Most cars don't need that as 800 is a lot of power in the 2v world.
2vjordy
Active User
Jul 19, 2017
  • Jul 19, 2017
What kind of power you think I would be at with what I posted and I'm not taking to track just want a street beast
squeak93
2,332
409
164
Joplin, Missouri
Jul 19, 2017
  • Jul 19, 2017
NO IDEA. I built a setup that should have made 500 all day that struggled to make 350 and ate itself on the dyno......
They make what they make.
I can say a blown trick flow headed setup with some compression will be a blast to drive and likely make some steam.
2vjordy
Active User
Jul 19, 2017
  • Jul 19, 2017
Thanks hopefully I get at least 450
2vjordy
Active User
Jul 19, 2017
  • Jul 19, 2017
Do you think my trans will hold 400hp flywheel
robertsa
Well-Known Member
Apr 22, 2017
159
44
58
San Antonio
Jul 20, 2017
  • Jul 20, 2017
If you go the route you're talking about, you're going to be at more than 400 at the flywheel. Also no, your transmission isn't going to like it unless you're very gentle with it. If you're going to baby it though, what's the point?
squeak93
2,332
409
164
Joplin, Missouri
Jul 20, 2017
  • Jul 20, 2017
It will, just not for long. The input shaft will waive by by. (I'm guessing a 5 speed). We broke a t45 with 379/475tq on the sauce. It lasted a year or so of abuse and went in a glorious way (at the track lol).
We also broke the rear end and about every other stock part along the way. You have to be sure to build the car to handle the power. Our n2o car had a lot of suspension work and would cut 1.5 60 ft times with that small amount of power and hang the hoops each pass. It worked well.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
L
Whats a safe limits to take this engine to?
  • LCATGA
  • Sep 3, 2024
2005 - 2014 S-197 Mustang -General/Talk- Sep 5, 2024
89ripper
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
