dlsdj said:Just wondering if a speed-cal is needed for this change?
coramprat said:The 3.55's are a good gear for th 5.0 engines but for the 4.6 the minimum I would go with is 3.73's.
I understand that. Pretty much a given if you are planning on S/C or turbo, go with 3.73's. I just think 3.27's to 3.55 is not going to gain a whole lot in any application using the 4.6. The 5.0 is a lower revving engine so 3.55's work better in most cases there. And if you decide on 3.73's or 4'10's then the Speedcal or computer flash is a must.00s281sc368 said:It depends how much power you make...
