3.73 gears ???
mustangsally93
281
Omaha,NE
Hey I just got a novi-1000 and still have the stock rear end (3.08) Is it smart to go to 3.73? Also if I change the rear end do I just change the gears in side or do I replace the rear end it-self?
Thanks for the help if you can.
3.55's will suffice with a power adder. When you do a gear swap, installing a posi differential such as an Eaton would be a good idea. You don't have to do anything with the stock housing, but adding a girdle can't hurt.
3:73 gears would be a good investment. You just change the gears inside if that's what you'd like to do.
You only need to take out the carrier and replace the ring / pinion to get the numerically higher gear ratio.
If your Trac loc is worn out, you can rebuild it with new clutches so you send power to both wheels again.
Or you can switch to an Eaton / Auburn style carrier that will drop right in and work with all of your stock parts + your new gears. The bennifit to the aftermarket carriers is they don't use clutches so they never wear out.
You won't need to swap your entire rear end unless you to the Turbocoupe swap (they come with rear disc's and 3.55 or 3.73 gears from the factory)
I say go with the 3.73 if you have the money i would also recomend upgrading to a 31 spline carrier and some racing axles. special if you plane on going to track with stickey tires. I twisted a axle shaft out at a track.
i agree, the 3:73s will make your car rocket with that novi 1000. your gonna need to make your rear a bit stronger.
