GinoGT said:I don't know about the exact gains, but you'll never forgive yourself for taking 3.73's over 4.10's.![]()
Dark Knight GT said:It depends on a lot of things. If he's driving an auto, then he wants no less than 4.10's. You can also run 4.10 gears with boost, many do it. Although it is easier with 3.73's.
If he's staying n/a, I say go with 4.10s, no less. Im planning on going 4.30's in my auto. Ide go with 4.56's but hey, I run a 26in tire and I drive my car everyday. Got to keep the interstate rpms down at least somewhat lol.
Conduct a search on here for both 3.73s and 4.10's. Read others results and judge for yourself.
03trubluGT said:I have seriously thought about 4.10s, but I drive 46 miles round trip to work everyday since I moved (down from 110 miles).....
I still think I'll do 3.73s though.. I really need to drive a car with both and make a decision so I can get it done.
Matt
GinoGT said:
And about the extra shift: yeah you do spend a little more time shifting, but the 3rd-4th shift is probably the easiest and fastest one there is.
speed545 said:would 3.90 be a good compromise??
trinity_gt said:Er...yeah. Well, my post still helps directly contrast the two...![]()
This is true. But at about 80-some MPH, where 3rd is nearing redline and you've got to shift, you're travelling at 117 feet per second. Even if you could pull off a shift in a quarter of a second, you'd still travel two car lengths (about 30 feet) coasting - no power being put down. Is this countered by the additional acceleration offered in 4th? Hmmm...
The final drive ratio in 3rd with 3.27s is 4.28 (1.31 * 3.27) while a 4.10 gearset in 4th gives a final drive of 4.10 (1.00 * 4.10). The overall ratios are pretty close. Engine RPM in 3rd at 80MPH is about 4620 with 3.27s while in 4th at 80MPH with 4.10s the RPM is 4400. Since the overall ratios are quite close, and both gears find the engine at very close to the same point in the RPM band, I wouldn't expect to get much more (if any) acceleration in 4th with 4.10s than I would in 3rd with 3.27s. Basically, the charge to the traps at the instant of shifting of a 4.10 car with a 3.27 car in 3rd beside him would be a wash.
GinoGT said:But I would think the extra time needed for the 3rd-4th shift doesn't mean anything, because with 4.10's second pulls almost as hard as 1st, and 1st with some sticky tires has got to be one crazy mother****er.
Getting a faster start gives better ET's.
trinity_gt said:If you cruise typically in 5th gear at 70MPH, with 3.27s your turning right around 2000RPM
