3.8 Automatic Trans Mustang will not shift
Dave559
Fresno, Ca
I recently had to fix a freezeplug located behind the engine, which required dropping the transmission. In the process of dropping and then reinstalling the transmission, my case connector plug was damaged and also needed to be replaced (which required me to open up a good deal of my transmission).
As things stand, the vehicle starts but the wheels will not turn. Any advice or insight would be greatly appreciated.
the main bulk head connector for the trans doesn't even need to be plugged in and the trans will still physically function
if the wheels are not turning then that would lead me to believe your gear shifter linkage is not putting it in the gear you think it is. Verify manual 1st gear and 2nd gear functions.
