306ci with Dss fly cut pistons for trick flow tw heads milled .0024, e-cam, trickflow track heat intake, pro-m 80 mm mass air, anderson power pipe, ramchargers eletric fan, pa-performance 160 3g alt,acufab 70mm tb,kirbin adj fuel pressure reg, 24 lb motorsport injectors, 180 stat, asp under drives ,spec stage 2 clutch steeda clutch quad&firewall adj, Tremec 3550 with pro 5.0 shifter ,frpp alum drive shaft,frpp 3:73's
frpp ceramic headers,mac off road h-pipe,2 1/2 mac cat back exhaust, mac subframes, msd 6 digital plus,autozone 3 core rad, msd blaster coil drive walbro 255lph high pressure pump, eaton 31 spline posi, superior 31 spline axles, trickflow rear end cover, mac adjustable pinion snubber, poly end links and poly spring isolators. i made 301 rwhp and 317 rwtq, when i had my t-5 and stock rear, after i put in a tremec 3550 and eaton posi and 31 splines and my nitrous plate it sucked me down to 276-307, im going back shortly to the dyno, i just put in a electric fan and a anderson powerpipe so i hope to get some thing back. if i could change cams id make more but i have to worry about the sniffer test soon, and i dint see it being worth it to take everything apart just to have 10-15 more hp, on the nitrous i made 413rwhp and 546rwtq and im emissions legal..
